Tin pan alley light help
Super cheese sandwich
in The Commons
Hi. I recently bought some lights for tin alley but when I applied it and render then I got a black image (Images attached)
I tried with all options in Environment mode but stills the black image. What can I do? Thanks!
I haven't used this set, but if you're rendering in IRAY and you're using a sky dome, the camera might be outside of the dome. If there is one, you'll want to delete it and choose an HDRI environment map, and add in a sun dial or photometric light and see how it works.
That light set might be for Daz Studio 3Delight only. You might want to try rendering it with 3DL and see what you get.
It looks like you are using this light set: http://www.daz3d.com/light-n-go-tin-pan-alley. It only works in 3DL and not in Iray
Thanks for the quick answers!
I tried with 3DL and it works
There is any light pack preset for day and night you recommend me for iray? Thanks!
Where says that? I couldn' find it :/
It doesn't say it, but it's a much older product than the DS inclusion of Iray. For the most part Iray lights will be described as such.
So If it's for daz 3 and older versions it's for 3DL? Could you recommend me a light pack for iray Richard?
Yes, anything for DS 3 or earlier will definitely not be for Iray, nor will older items for DS4. Most light sets are for one engine only, if it doesn't explicitly say (in title or description) that it is for Iray assume it is for 3Delight.
