Victorian Innocence: Bundle Complete Question
Knittingmommy
Anyone who has purchased this, can you tell me if you had any problems installing the Neo-VITextureExp-Bundle that came in it? Everything else installed fine, but that one had a problem.
I got the following error:
- The "IM00029976-01_NeoVITextureExpBundle.zip" file is invalid. It does not contain a manifest, or is corrupt. The product cannot be installed.
Just thought I'd ask before filing a help ticket to see if anyone actually managed to get that installed. I tried deleting and downloading again, but that didn't work. Thanks.
Edit: I forgot to add that I did double check and there is a Manifest file inside the zipfile.
Post edited by Knittingmommy on
Yes. It was in my product updates today and still gave that error message.
Well, I sent in a Help Request. Now, I just wait.
Yep. Bought it for the hat and googles, haven't been able to use it. Pretty much just wrote it off as a loss for the moment.
Well, I got a reply to my ticket. Says they are looking into it.
I got the same result.
The tip is much appreciated, everyone. I bought it, but will delay installing it until they get it fixed.
Would you guys please post a note here when that happens? Thanks!
I bought it, but haven't installed it yet.
I'll post with updates if they get back to me about my ticket. I really like that texture set and really wanted to use it soon.
I just tried to install it.
It is not fixed.
The problem is that the DIM/zip file is misformed. The Content folder and the Manifest and supplement are supposed to be on the top level of the zip, but they're within another folder. fig 1
You can manually fix it by unzipping the DIM and rezipping it corretly. fig 2
I've sent in the info with a bug report to get added to the other.
I got an email the other day that they have verified a problem and it was being reported to the proper person to be fixed. Said I would get an update when it was fixed. I'll update the thread as soon as I hear about an update ready for download in DIM.
Thanks for the info. I might give that a try if I don't hear soon because I'd really like to use the textures in a render!
I tried to fix it manually by removing the top folder (several tries), didn't work for some reason (Install Failed each time).
Correction - it does appear to install (no "Install Failed" message), but if you look at the file on the "Installed" tab in DIM it's 0 bytes.
Well, maybe I'll wait for a proper update then. I'm hopeful I'll hear back soon that the problem has been fixed.
Just a quick Heads Up.
I haven't heard anything back from Customer Services but I tried again to download and install it. And it installed with DIM.
So, anybody still waiting on this may want to try downloading and installing it again.
I'll give that a try here in a bit. I haven't heard anything from CS either yet.
It was listed as an update in my DIM today, and installed fine, so I guess it's been fixed now.
