DAZ Studio and memory overclocks
For some reason, DAZ Studio only responds to GPU Core clock speed OCs from MSI Afterburner (ie. Rivatuner) but not memory clock OCs. Is this because it's using Iray/CUDA functionalities instead of standard GPU usage?
  • prixatprixat Posts: 1,617
    I'd expect a memory OC to help with faster transfers of data.
    Since Iray only does that one large transfer to fit the whole scene onto the card, what you're seeing sounds right.
  • mtl1mtl1 Posts: 1,508
    Ah this makes perfect sense now. Thank you!
