M4 morphs for V4
I know I can have a figure where M4 can use V4 morphs, but now I need the oppisuite.
I need V4 to be able to use M4 morphs. I have a set of creature face morphs and I want to have both male and female of the creature, but there is not set of these morphs for V4. How can I work around this??
thx
  • BeeMKayBeeMKay Posts: 7,019
    edited August 2016
    Deleted. The product I had in mind only transfer to Genesis,not back down. Sorry!
    Post edited by BeeMKay on
  • ByrdieByrdie Posts: 1,783
    I have my M4 and V4 figures set up to use each other's morphs. What you need to do -- and always be sure to make a back up of it first in case of accidents! -- is copy the M4 subfolder from your !Daz folder into the V4 one. Then run the V4 .bat file so it will add them into your figure. After that Vicky should be fully capable of using any of Mike's characters. But you'll have to either convert with Texture Converter or whatever or else go about remapping a copy of your V4 .obj if you want to use any of his skins on your modified model.
    Hope that helps. Used to be a tutorial around the old forums that could explain the steps much better than I can, maybe somebody knows where it is.
