Tilly
Tilly Discount not showing:
http://www.daz3d.com/plushies-tilly
When I go to check out the discount will not show, it says $10.00
Anyone know if it has been taken off sale?
Thank you!
  • LinwellyLinwelly Posts: 6,070
    It shows to me for 2.99 (I guess that is pc price). What discount did you expect? Sometimes it helps to referesh the cart before continuing.
  • digitelldigitell Posts: 588
    Hi Linwelly,
    Thank you, It is suppose to be 2.99. I am a PC member too so it should apply to me.
    Thank you for posting tho..guess it must be a glitch or something.
  • nonesuch00nonesuch00 Posts: 18,830
    edited August 2016
    That is usually solved by checking to make sure you are logged in & if you are then just reload the page and that should fix it.
    Post edited by nonesuch00 on
    Maybe try to log out once and log in again? If that does not help, see if the problem comes up with similar other items, if that is the case you should contact support.
