The Deadliest Mixer - Does not appear to work in DAZ
in The Commons
I do not see any new morphs after injecting these on M4 in DAZ.
Must be Poser only.
JD
Must be Poser only.
JD
where you looking for them. Most Poser morphs will show in the parameter dials or sliders. So the head and neck morphs should show when you select the haead of M$ and check the parameters (or whatever they are called in DS)
This may be another former RuntimeDNA product that uses PMD files. There are a lot of products from there that would never have passed DAZ's QC.
It does list only Poser as a compatible application.
OK, so I unzipped it to my M4 runtime and injected into M4 (in Poser) In the readme it tells me that the injections are applied at body level, not at body part level, so I selected body and find new parameters titeld
Deadliest bodies
Deadliest heads
Deadliest teeth.
In Poser these parameter dials appear before alll the normal dials
Yes and if you repeat this process in DAZ?
I don't see these dials.
JD
Yes, as Richard says it is listed in the store as being Poser only.
"OMG it's the Betty's" - is the same case.
Just a heads up!
JD
Well, even though it is in the store as Poser only, with DAZ's very liberal return policy you can still return it for a full refund within 30 days of purchase
