Genesis Starter Pack wont show up and I have a error message
squirtsquirt Posts: 170
I'm getting this error message: An errror occurred importing addon dson :
ERROR: DLL load failed: %1 is not a valid Win32 application.
This happens on the 64bit version of Poser Pro
But does the error does not show up for the 32 bit version of it.
Also, Dson did make it into my Scripts of Poser Pro.. But none of the Genesis Starter pack with show up in the Library..
Does anyone know what I can do?
  • Richard HaseltineRichard Haseltine Posts: 108,441
    Is this the opriginal version (.9) or the latest update (.13)? The original needs particular versions of the MS Visual C++ Runtimes, which you may not have if you don't have an application (such as DS) installed that uses them - the new version includes them.
    As for the content, did you install the companion files (and the core files if you don't have DS) to the folder you selected as your Poser content library? Usually "Poser Pro 2012 Content", by default in your Documents folder.
