Decimator not allowing me to decimate Hair below 37 percent
It's weird, all the things decimate to whatever i want but this one hair doesn't let me. At first i checked it's options wheel and it was set at limit of 37 to 100 percent.
 So i changed it to 0 to 100 but not even that helped. It's a hair called "Goya Hair" for M4. Like i said all other hairs i've been able to decimate but not this one so the most polys i can get down to is 75000 and that's no good cause Unity only wants things like under 64000 or sometehing. and i'm exporting to import into Unity
  • nonesuch00nonesuch00 Posts: 18,763
    That is odd, I've decimated some models with good results all the way down to 10% and a few less even.
  • nokoteb99nokoteb99 Posts: 931
    yes it is. I have to find a solution soon or give that hair up and use a simpler one.
    I ended up giving up. it still goes only down to 37 percent which is 75000 and i tried changing the settings for limits but it doesn't obey . So i bought some new hairs to see it i have luck :)
