Are there textures for males without Facial hair?
Ther'e s a thing called "Growning up" . It's a product where you can make your G2Male or G2Female into a kid, teen or whatever. But wellfor girls is ok because women dont have moustache or a 5 oclock shadow, facial hair. But most textures for Genesis 2 Male or any male in fact contain facial hair like what you get after shaving,you still see the shadow. So when you use that product to make a 10 year old kid, he's gonna have facial hair.
The only solution would be to get textures that don't have facial hair but none of them are that way. ALl male textures contain facial hair. even if it's alittle.
Have you looked at http://www.daz3d.com/brothers-for-growing-up-genesis-2-male-s-m6
Try these:
http://www.daz3d.com/snowflake-for-aiko-7 (there are 'natural' makeup & 'peach' makeup options - manually switch the eyelash transmaps with a more masculine set)
http://www.daz3d.com/genesis-3-uv-swap-male-and-female-base (so G3M & G3F can swap textures - I'm sure it's more popular to put a female texture on male then vice versa)
and will start buying for Lyoness in particular because she said she has no makeup & no eyebrows options on her characters:
http://www.daz3d.com/lyoness
It's also worth noting, but I am not 100% sure that the last two male characters from DAZ look as if they might have hairless options, for example useful if you want to use Look At My Hair (LAMH). I've only bought LAMH so ask others about Kenji 7 & Donnie:
http://www.daz3d.com/kenji-7 (looks that way but I'm not sure on eyebrows, and scalp)
http://www.daz3d.com/donnie-for-genesis-3-male-s (not sure on eyebrows & scalp)
http://www.daz3d.com/look-at-my-hair
I do pretty much all of my texturing using Female Base UVs and female textures (so I can do a texture setup on one figure and quickly apply it to another, male or female, without much fuss), and then add polygonal stubble using either Mec4D's facial hair or Laticis facial hair. Xtreme Merchant Resources are what I tend to use as a base for customising my skins. The less baked in lighting the better, as far as I'm concerned, and I have versions of the Xtreme textures with more of the baked lighting and eyebrows removed in Photoshop (eyebrows are now usually OhMyBrows or the ones you get with Wise Sensei). Beard pores can be added using Photoshop.
http://www.daz3d.com/xtreme-merchant-resources-set-01
http://www.daz3d.com/mec4d-unshaven-2-for-genesis-2-male-s
http://www.daz3d.com/whiskers-for-genesis-3-male-s
I found a character who has one option that looks like he doesnt have any facial hair. It's Truman. i thnk from rendesity. I used it on a child, and i don't see facial hair. SO i'm ok now i guess for now
