G3M - Genital bulge messes with G2M auto-fit clothing!
2»
  • nonesuch00nonesuch00 Posts: 18,763
    Well I just fit the Slosh Sailor outfit on Genesis 3 Male and while the crotch was there and stayed covered what happened was one of the upper thighs showed though. It was set to 'smooth' a default of 3 iterations I didn't set that. I tried upping the number of smoothing fitting iterations to 5, 10, 25, 50, 100 but that completely deformed the fellow so what did would was set the number of smoothing iterations to 0 and the FBMExpansion parameter to I think it was 5% or 7% and that solved the problem.
    I think though the poke through on the thigh showed up because I made the legs shorter, the hips, waist, and torso longer, but I didn't change the thickness of the thighs or legs when doing that.
    Another weird thing is on the jumper bell bottom cuffs there are these wierd artifacts of some sort that look like a peach or tan colored thread.
    Otherwise everything is fitting without artifacts.
