Mesh broken with Gia 7 HD Add-on
HirokazHirokaz Posts: 24
I'm using Gia 7 HD add-on and I found a broken part of the mesh on my G3F model.
So I set 100% on Gia 7 body and 100% on Gia 7 body HD details, then the broken part appears on the pinky finger of her feet as in the attached pictures. SubDivision Level is set 2.
When I set 0% on one of the above parameters, or set the Subdivision Level to 1, I don't get the broken part.
Is this a bug on Gia 7 HD Add-on?
  • Richard HaseltineRichard Haseltine Posts: 109,523
    I'm not seeing that in the zeroed figure (with the morphs set). Does it appear only with that pose?
    I can get a tiny break if I bend and twist Left Small Toe 4, though not to the extent you are seeing.
  • HirokazHirokaz Posts: 24
    @Richard
    It appears in every pose even the default.
    Are you sure that, aside from Gia 7, Gia 7 HD, and the SubD level there are no other morphs or poses applied? A freshly loaded Gia 7 HD Details with the SubD lelvel upped to 2 does not show any issue for me in the release build of DS.
    I tried loading a fresh Gia 7 and apply Gia 7 HD. Yes, there's a broken part inside of the pinky finger. It's clear when I see it in Wire Shaded mode. The picture is attached. The square-like polygon pops up.
    When Gia 7 morph is off and only Gia 7 HD, there's still a funny small broken part there.
    841 x 839 - 123K
    Oh also I'm using Daz 4.8, is that the problem?
    It may be exacerbating the problem, at least - as I said, I can get an issue but not as readily as you appear to be.
