mcjhorizontalizeshoes - Quickly align shoe soles with the floor (animated too)
mCasualmCasual Posts: 4,607
edited July 2016 in Freebies
Free Script for DazStudio all versions
version 2 was posted, not a big change but it 'memorizes' your settings
version3 you can now load/save the positions/rotations/scalings of your sole-planes
https://sites.google.com/site/mcasualsdazscripts7/mcjhorizontalizeshoes
Purpose
Quickly re-orient feet so that the shoe soles are horizontal
Use
For each foot of your figure.
Create a primitive plane, any size will do.
In the plane creation options, 'primary Axis' must be 'Y Positive'.
In Daz Studio's 'scene' tab, rename them 'lSole' and 'rSole'.
Parent each plane to its respective foot.
Orient the planes like their respective shoe soles.
( As if the shoe soles were sticky and you walked on a sheet of paper )
Note that there's also a button titled "Create Sole Planes"
Which will create and roughly position those planes
But you will need to readjust them for your specific shoes
Run the script
Select the appropriate timerange.
click the 'Go' button.
The feet will be bent/twisted just the right amount
to make the shoe soles ( the planes ) horizontal.
image\
Post edited by mCasual on
  • nakamuram002nakamuram002 Posts: 811
    Thanks Casual!!
    This sounds wonderful!!  Will have to play with it.
  • MythmakerMythmaker Posts: 606
    AWWWESSSSOME!!!
    What would locomotion life be in DS without Jacque?
    Skating princesses and floor mopping feet!
    Now I go play with it!
  • mCasualmCasual Posts: 4,607
    edited July 2016
    Mini Update - Version 2 - Mini Update - Version 2 - Mini Update
    the script now saves your 4 settings upon exit and recalls them when you come back
    I tried this with high heels.  I think that it wold be better to align the planes with the shoes (or use planes that were pre-aligned with the shoes), rather than aligning them with the character.
    well it takes only a few minutes to align them with the specific shoes in a scene, once it's done it saves a lot of time
    shoes are so different from case to case that i prefered not trying to make presets
    though something that would not be too hard would be to have a "Save Soles" button
    so if you position the planes for specific shoes and a specific figure "manually" you could save that position/orientation in a .dsa file using that button
    then another day you'd use "Load Soles" button, it would re-generate the soleplanes, parent and position them
    i'll do that right now, and post it as version 3 when it's ready
    edited July 2016
    UPDATE V3 UPDATE V3 UPDATE V3 UPDATE V3 UPDATE
    July 30th 2016 - 10:13pm - version3, you can now
    661 x 540 - 50K
  • dHandledHandle Posts: 617
    Ok..phew!  Figured it out...
    I thought something went wrong with the download/update since I was overwriting the original.  Or maybe not..I don't know.  When I looked at the script dialog after opening it, it still said "V2".
    But that's ok..it has the correct updates,
    Anyway, thanks Jacques!  Very cool!  You always come up with the most useful stuff!
    smiley
  • laststand6522732laststand6522732 Posts: 866
    edited December 2016
    Your script handles parallelism with the floor well.  Thank you, it will save some time.  Have you considered expanding on this a bit?
    Post edited by laststand6522732 on
    well someday i'd like to have a script that helps automatically lay a hand on a surface inclusing posing the fingers,
    but my next projects are ( if i remember well )  a top/dress for Aiko3, Kinect Facial Mocap ( PC old sensors only ), and physics
    and dozens ( really ) of other projects on the backburner
    600 x 338 - 1M
    Of course.  So many projects, so little time.
