How to clear the timeline?
info a411info a411 Posts: 0
I am struggling a bit with key frames.
I added a few key frames, and it seemed to be working, but I decided things were not as I wanted, so I deleted the key frames.
Now when I move across the timeline, things still move around even though there are no key frames.
Even when I add new key frames, there are still bits of movement in there which seem to come from the old frames.
What am I doing wrong?
(If it is relevant, I am also using Lip Synch).
  • bighbigh Posts: 8,147
    under edit - figure - clear
    adding lip sync after the animation is what you want is the best way
  • Richard HaseltineRichard Haseltine Posts: 109,018
    Clearing or deleting keys affects only the currently selected nodes - if there are keyframes on other nodes they will remain, which is, I suspect, your issue.
  • info a411info a411 Posts: 0
    Thank you. Suddenly it all makes sense!
