MC6 to PZ2 Batch Converter
2»
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    This looks like a great tool but I'm getting an error.  Any help is appreciated.
    997 x 462 - 128K
  • EddyMI3DEddyMI3D Posts: 365
    Just sent yo an PM...
    Just uploaded a new version with a tiny error routine
    Thank you so much for this tool. After a little hiccup and tremendous support from EddyMI3D, I got it running and everything is on and poppin!!!
    - BLUSH! blush -
  • wgdjohnwgdjohn Posts: 2,634
    Thanks Eddy!
  • It doesnt work on Windows 7. I open the file but the windows never appears.
  • DartanbeckDartanbeck Posts: 21,988
    EddyMI3D said:
    - BLUSH! blush -
    Now THAT'S Customer Service! Darn it Eddy MI, You Fricken'  R O C K ! ! ! ;)
    So Awesome!!!
    Hello!
    That is quite strange. I programmed it on Winows 7.
    I've downloaded it to secure the upload is ok.
    Have you been able to unpack it without problem?
    Eddy
    Try adding it to an exceptions list in your antivirus/firwall programs
    Bummer.
    I've tried everything I can think of. I get it to show up as running in the task bar, but no window ever opens. So I try just dragging some files onto the running thing in the task bar, but to no avail.
    So I set it to run as administrator, gave it permissions, already told my firewall it was okay to run, and finally set to run in compatibility mode for Windows 7 - trying to run it between all of those steps.
    Am I missing something simple?
  • StezzaStezza Posts: 8,819
    where is the program file located?
    If you haven't move it to a folder off the root directory of any of your hard drives and try...
    eg.. d:/Converter/mc6_to_pz2.exe
    Yes, it shouild run at any location.
    For I have no Windows 10, I have no clue what the problem could be. - Sorry.
  • PhilWPhilW Posts: 5,162
    I get the window opening as it should and I am on Windows 10.
  • SileneUKSileneUK Posts: 1,977
    Mine is on my desktop on Windows 7 and I open it there and the browse for the files in the directory where they are located.  yes Silene
  • mine is on my F drive and works fine mostly
    there are some files it cannot do from RDNA, but most work.
    Cool.
    I'll try it on my other (Win 7) machine ;)
  • dbdigital2dbdigital2 Posts: 270
    edited December 2018
    I realize this is a OLD thread, but being I just tried the converter and had the same problem with it running but can't see the window.  However, I have a fix.
    Run it and click on the program in your task bar so you know it is on top, even though you can't see it.  If you click it again you should see the minimize animation coming from the far right.  If you do, click it again so it is on top.  Then hold down the windows key and press the left arrow key once or twice.  It should move it back into view.  You might need to press it several times.
    This works for any window that has went off screen.
    Post edited by dbdigital2 on
