Garage Door Rigging Tutorial?
pfunkyfize
Hi all,
I am learning about rigging for DAZ and found some good tutorials but can anyone explain how I would go about rigging a sliding electric garage door that slides along inner guide rails inside the garage? Not the lateral sliding kind on the garage's exterior. That would be easy to make though...
Basically I need to rig a 3d model of this so the door slides along the rail.
Thanks!
Post edited by pfunkyfize on
I think I would probably used Keyed ERC with those controls set to Linear.
Thanks I will have to look up what all that means
I did something similar in Room Creator Exteriors. The garage door moves up on a rail and simulataneously rotates outward.
And yes, it can only be done with ERC. ERC (Enhanced Remote Control) is a way to combine multiple parameters into 1 slider - in this case Ytrans + Xrot. You can also do all sorts of other clever things with it, like setting multiple delays to turn the pages of a book in sequence. (I did that in my Model Agency).
Of course, the snag is that it takes quite a bit of learning. I've always done it manually - hacking the .cr2 in Poser - but DAZ Studio has some new simpler ways of doing it. To be honest, I've never bothered learning ERC in DS, since I haven't needed to use it in a long time, so I'm afraid I can't help you there.
All I can tell you is that if you want a sectioned door that follows the rail - as opposed to a single flat door - you'll need to build it in.... umm.... 40 -50 sections and ERC them all with Ytrans, Ztrans and Xrot. It would be quite an undertaking!
mac
Ah no wonder I don't see any garage doors that follow a rail! And my version would actually be a rail and the door wouldn't swing outward at all as it dragss upward. Thanks for the insight on that!
