poses question
in The Commons
when i see alot of v7 and m7 stuff like poses can i use other g3f and g3m figures with the poses?
Yes, but you may have to adjust them, especially if you change your figures from being the same height.
This was made with one of the poses from http://www.daz3d.com/beloved-poses-2 but it required quite a bit of tweaking because the characters are very much not the default height.
i really appreate it i dont own m7 and i was jw if i could use any other poses that invovle his character
Oh, totally. Again, you may have to tweak, because the poses are set for his shape, so if you have a hand on a hip, you may have to move the arm to make it actually be on the hip or not intersecting, but it's not hard to do.
I agree, most poses you can use with whatever figure you want as long as you are prepared to do a little tweaking. Most poses being used on a different character, but within the same generation usually need tweaking with the hands on the hips type of poses and possibly foot placement. Really easy tweaks. For extreme transfers between generations, some poses might work and others need a little help and Pose Converter can help with that if you're going from G2 to G3. They might still need some tweaking, but not as much as if you were trying to put a G2 pose straight onto a G3 figure.
