Ready - The return of mcjIsosurface plugin for PC-Win and DS 4.X
2
  • mCasualmCasual Posts: 4,607
    jag11 said:
    Awesome! Video at 0:16 seems like a heart beating. Please post the script to do that.
    i called it the boiling surface effect
     it's metaballs bouncing up and down
    one of the problems with those scripts is that i was adjusting them "by hand" and you need to be a daz script programmer to do that
    but the plan was to make them usable by anyone and maybe have 1 script for all effects
    if it's not too much work, i'll post the boilingplate effect script,
    but it may have to wait untill i complete the task at hand:  the mcjIsoSurface for IRay update
    edited August 2015
    i found the (2011) script for the boiling-plate effect and it works well with the mcjIsosurface4
    it's not adjustable but someday will be
    see if your daz studio 4.8 Preferences/Interface/Pixel Shading" option is ON and the Reflection Map of a surface has an image applied to it, you get Real-Time Display of the chrome/mirror effect
    though now if i remember well you get the same effect by applying it to the diffuse channel --- because the isosurface uses a spherical UV map
    724 x 700 - 148K
    Post edited by mCasual on
    edited August 2015
    first animated blob ( it's just paint !!! ) rendered with IRay
    oh now i understand why the metaballs are not jumping !
    i prevented them from reaching the floor !
    contrary to initial intent, i'll release the script for this effect with a User Interface
    so you'll be able to adjust things
    edited August 2015
    it's more complicated than just running the script,
    but, you get to tailor the effect to your liking
    the script will be posted on a different page than the isosurface plugins ( because they have other uses! )
    here we'll make a 30 frames long effect
    checking the metaballs paths through a 30 frames "cycle" and we can see it's not looping
    Since it uses parabolas and random initial speed and directions, it's understandable that we dont get bounces with very predictable durations
    but but but i could weed out the bounces that are not fully encompassed by the looping animation-range
    so instead of Y.O.L.O. it would be YOLAINOTWTAR You Only Live An Integral Number Of Times Within The Animation Range
    But ah HA! back in 2011 i wrote the looping version!
    800 x 664 - 171K
    800 x 800 - 32K
    800 x 800 - 38K
    edited August 2015
    n
    edited August 2015
    mcjFXBoilerPlateB
    The first mcjFX script which creates animated metaballs ... so that the Isosurface looks like this
    was posted a moment ago !
    https://sites.google.com/site/mcasualsdazscripts6/mcjfx
    there may even be a manual tomorrow
    in the meantime you'll have to figure the settings or leave them un-modified ( and there's a reset button ... which i didnt test actually )
  • jag11jag11 Posts: 885
    Thanks for the mcjFX.
    edited August 2015
    someday someday i'll rewrite the polygonizer part of the plugin and get rid of the mataAnnoyingLines
    in other isosurface news, - next version will have the visible domain box and sane transforms handling
    800 x 450 - 356K
    edited August 2015
    but but but
    as we can see here upon a close inspection
    is that the lines are not only due to the variable spacing between edges
    there's vertex positioning imperfections ... possibly due to a loss of precision somewhere ..
    maybe if i fix that, the appearance will be acceptable!
    800 x 450 - 6K
    edited August 2015
    this weekend i'll work on the more-iRay-Friendly mcjIsosurface4
    since i didnt remove the code for it, the mcjIsosurface node still renders itself in 3Delight mode
    the top sphere is the mcjIsosurface node, as you can see, the plugin does a better job, because it uses computed normals instead of facet normals
    the bottom sphere is the "it" node which was hijacked by mcjIsosurface and is rendered by Daz Studio and/or iRay, like any normal primitive
    changes i expect to do this weekend
    - make the mcjIsosurface and "it" node positions, rotations and scaling conform to one another
    - make sure it's possible in 3Delight mode to turn on/off the mcjIsoSurface old but good rendering
    - fix the imprecision in vertex positioning
    - possibly add a decimation option where the plugin merges all the vertices that have a distance smaller than a certain distance
    i did a test, i created an isosurface sphere
    exported the isosurface using Daz Studio's obj exporter
    imported it back in Daz Studio
    ran a script that measures the radius at each vertex
    and i can report that the radii were
    Executing Script...min max = 9.995745658874512 10.013422966003418
    that's in centimeters
    1148 x 1004 - 1M
    edited August 2015
    i'm not there yet, but if all goes well the result will be like the ball on the right
    instead of the one on the left
    but you could say this was fixed "manually" i still didnt find what's wrong with mcjIsosurface3 and 4
    maybe it's something that appeared in DS4.5 or 4.7 ... tests to do
    800 x 450 - 482K
    edited August 2015
    this post was a duplicate
  • hphoenixhphoenix Posts: 1,335
    The ball on the left looks like the marching-cubes aren't smoothing properly....the one on the right has some normal issues, but appears smooth.
    edited August 2015
    note that this was using the "metanuball"
    i tested mcjisosurface3 in DS3-64 bit and it's the same
    the "metaball" primitives seem to look similar to the ball on the right
    by stepping up the resolution of the mcjIsosurface ( in the parameters tab ) the defects become less apparent
    dont know yet if there will be anything i can do to improve the looks other than changing the polygonizer
    note that my reference for all this is http://paulbourke.net/geometry/polygonise/
    one thing i may do is reduce the number of edges by not triangulating the quads
    this should smoothen the meshes a bit
    http://mathematica.stackexchange.com/questions/80669/integrating-a-function-over-a-surface-integral
    edited August 2015
    laboratory "monster" while trying the repair the metanuball primitive
    today's conclusion is that i'm not certain what i was trying to accomplish with the metanuball primitive
    but until i do, you can get good results using the metaball and metasphere primitives
    i probably left the metanuball in the mcjMetaConsole palette for backward compatibility
    tomorrow i'll study other ways to improve mcjIsosurface
    i did a few modifications on my copy that do help, and at a minimum you'll get those tomorrow
    or if you're really really insisting, here's the nightly build for 64-bit
    mcjIsosurface4 64 bitearly 08292015 Morning zip
    800 x 450 - 211K
    the laboratory "monster" has some cuteness , mathematically speaking i mean, no quasi-degenerate thin-sliver-triangles,
    Hmm.  And have you considered an octree traversal algorithm instead of marching cubes?  There's plenty of info on variations used for isosurface reconstruction, and can easily result in considerable speedups from the brute-force marching cubes.  As an example:  https://users.soe.ucsc.edu/~avg/Papers/oct92.pdf
  • RAMWolffRAMWolff Posts: 10,347
    Interesting project.  Cool too!  cool
    i think i'm using marching tetrahedrons, but i dont want to spend more than this weekend on the isoSurface plugin
    i actually have projects on the backburner goiung back to oh about 2010 .... that's a lot of baccklog to tend to
    my mcjCollider plugin and some scripts would benefit from speedups offered by spatial partitioning
    it's all free/hobby/toy gizmos so i'm happy with them as they are
    edited September 2015
    good news, our research team ( thinks it ) has located the source of the isosurface4 (and 3 i guess) banding defects
    there was a line in the code that looked like d += 0.0001;
    i was adding a small tweak to avoid zero division or some "fence" issues
    but apparently 0.0001 is not small enough of a tweak to go unnoticed visually
    so i changed it to d += 0.000001 and looks like that does the trick
    the updated version will be posted in the daz3d freepository forum later today
    i want to improve the domain vs isosurface  relations
    iRay render here
    the red ball is the isosurface, since it exceeds the "domain" it gets truncated
    the Utah teapot ( 4 pieces ) is a free prop on my web site
    for a moment there i had doubts !
    the defects were so small
    but in this extreme closeup of a small metaball
    you see in red an mcjIsosurface4 ( with the corrected code )
    and in white an mcjIsoSurface3 ( with the old code )
    and there is a difference
    so we indeed fixed that issue
    fig 2 - the 'metaball' primitive is one of the few primitives which given a negative radius give us a subtractive effect
    fig 3 the red metaball on the left is a "metanuball", the one on the right is a standard metaball
    the banding on the metanuball is not due to a problem with the isosurface,
    the metanuball was an experimental thing and in fact i dont quite remember what was the goal
    1920 x 1080 - 175K
    976 x 601 - 633K
    1920 x 1080 - 304K
    I have no idea about any of this but as usual your brilliant and thanks  to your team for their discovery!
    well actually the metacylinder still exhibit the problem ... the case continues
    976 x 601 - 299K
    I think the original vertex interpolation code you are using was based on using float and double type elements, back on old hardware.  And it was based around a domain that was fairly large compared to the isolation value (0.0001) to avoid NaN issues.  The double type values were used to give 'room' for division/multiplication results.
    However, either way, with modern hardware (32-bit/64-bit) a double is a LOT bigger for most compilers.  Instead of using a numeric 0.0001 (or 0.000001), #define a constant in your header files like
    #define MINIMUM_DIV 0.000001
    so that you can just change it there, and have all those comparisons use the identifier instead of the direct value.  And since a modern 64-bit double (IEEE 754 standard) can go as low as
    0.0000000000000002
    in representing fractional parts, you could use a much smaller value (though give a few orders of magnitude above that limit, so that if you scale up the domain, it doesn't become an issue).
    Now, depending on which C++ compiler you are using, the "long double" is an option (on just about everything but MS Visual Studio) as it extends the double to a 80-bit field.  In MSVC, a "long double" is the same size as a "double".
    I'm still working on my algorithm for dynamic octree spatial partitioning so that it works with continuous functions (as most implementations are designed to work with point sets, so it's just a lookup for containment, rather than evaluation a scalar field, which seriously complicates determining if a octant should be subdivided or if it should be considered 'empty'.....) but when I get it worked out, I'll pass you a copy of the sample implementation.  Might be a good optimization for a few of your plugins!
    Keep up the good work!
    (and the metacylinder image.....is that TWO metacylinders meeting, or what?  That banding looks to be localized to the extreme curvature region.....)
    it was a birdeye view of a metatube showing a dent
    the mataballs now seem to look good
    but other metashapes like the metatubes still have the problem
    note that when you increase the resolution, or animate the iso or add a texture the problem becomes less visible
    i'll give it another go in the next days
    about the precision, i think using the small number like 0.0000001 was helpful, but in the end i changed the method and dont need it anymore
    i did as ... probably Paul Bourke ... did here around line 00508
    http://www.ks.uiuc.edu/Research/vmd/doxygen/Isosurface_8C-source.html
    well ... i seem to have improved the softness of the mataballs primitives but other metashapes like the metaspheres still suffer from ripple/bands defects
    tomorrow or next weekend i'll give it another go
    i may post the slightly improved plugin later this evening
    https://sites.google.com/site/mcasualsdazscripts5/mcjisosurface4-beta-20150802-plugin-for-ds4-8
    the current development version 64 bit plugin in a zip file
  • MythmakerMythmaker Posts: 606
    edited July 2016
    I just tried the isosurface4 all 3 versions, only the latest beta 03/09/15 version will have the wireframe show up in the viewport.
    But wireframe yes/no options didn't show up under Parameters, just Geometry: 'resolution x32' and 'show doman box' only.
    I've set default wiremap Reflection map to 100%, diffuse/ambient 0. Metaconsole metaball/cubes etc still don't show in viewport or actual render.
    Changing the engine to 3DL did nothing. Changing shader to iray uber base, no change.
    Same with boilerplate. Both the isosurface object and boilerplate do exist in the scene as shown.
    Most likely a 4.9 issue....?
    In any case, no hurry. Just thought I put the report here for 4.9.2.7.
    This is my first attempt at isosurface anyway so let me know if I missed specific steps... Cheers
    516 x 390 - 40K
    Post edited by Mythmaker on
    looks like it's broken for earlier versions of Ds4.9 too
    worked last summer but ...
    i suspect the isosurface doesnt "see" the meta-objects
    i think the isosurface plugin scans the scene for objects with specific names like "metaball"
    i'f i'm lucky it's just a matter of renaming them ( which is different from re-labeling them )
    i'll check this after supper which is now !
    end of 2015 following a hardware disaster i lost the DS4.8 / 2015 version source code for this plugin
    i still have older DS3 versions and can probably remember how i made it DS4.8 then iRay compatible
    but it will take some time before i have time to work on this
  • mtl1mtl1 Posts: 1,508
    @mCasual, have you considered hosting your code on an online repository to prevent such hardware disasters? :) Aside from your own website, of course!
