Need help transfering morphs
lcahpowelllcahpowell Posts: 14
edited July 2016 in New Users
So i created a custom character morph in zbrush a while ago for the genesis 2 female. The morph works wonderfully in daz on the genesis 2 base. Since genesis 3 has come out I have been trying to figure out how to transfer this morph to the genesis 3 base. I purchased genx2 and the genesis 2 and 3 addons but I seem to be having trouble. I have read several tutorials and I'm still having trouble. WHen I drag the character file from the content window to the genx transfer window I get a pop-up saying it's loading but then nothing happens and their is nothing to select. I could really use help. The morph is a likeness of a friend and took several days in zbrush to get right. I would hate to have to scrap it and start over. Any help would be appreciated.
Sincerely,
-Dan
Post edited by lcahpowell on
  • nonesuch00nonesuch00 Posts: 18,830
    Sincerely,
    -Dan
    It sounds like a problem that the business that develops genX2 needs to address. They'll ask you for support logs from their app & such things and give you a solution or fix their code.
  • lcahpowelllcahpowell Posts: 14
    So I figured it out. I didn't realize that the character morph that I originally created shows up under the list of genesis 2 morphs that load when you choose genesis 2 as your source. Next I just had to figure out that after transfering the morph you need to turn on the genesis 2 morph under shaping/actor/generationx and then find the character morph under parameters/genesis 3 female/generationx. Thanks for the comments though.
    Sincerely,
    -Dan
    Sincerely,
    -Dan
    Good to hear it works OK.
