DAZ Studio 4.9.2 Crashing when opening saved work?
Hi,
I am using DAZ Pro 4.9.2 64 Bit
I was working with a G3M Base with Spartan Outfit and Boris Hair. I added a Swole 7 morph.
I added a G2F Base with Serpent Hair and Severed Man Neck Cap so I can delete her body and only wanted the head to look dicapitated. I rendered everything in iRay just fine. I have a Windows 10 64 Bit operating system Toshiba Satellite C75D-A AMD A-6 with 16 GB of Ram. My problem is I saved my work as I usually do DUF File. When I restart DAZ and open my work it crashes on me??? I have participation online unchecked and I even turned off my internet connection to see if it was a network problem. It still crashes on me when I go to open my saved scene. Attached is my snap shot of my error. I submitted a support ticket also.
Any suggestions? Thanks
  • Richard HaseltineRichard Haseltine Posts: 109,107
    Is it just this scene? If you reload the content (but don't bother about applying poses etc.) and save as a scene (under a different name) will that open? Are you opening with DS running, or are you double-clicking the .duf file to open DS? If the latter try the former.
