Albane and Ali II (Albino skins) [commercial]
2»
  • vwranglervwrangler Posts: 4,978
    edited July 2016
    Where are the matterial setting for his elements?
    He doesn't have one. What he has is a Hierarchical Material preset for his whole body plus elements. You'll need to attach said Elements, select his main body, then use the Albane 02 MAT1 (either 3Delight or Iray) H.Materials preset. Once that's on, if you want a separate preset, you can select the genitalia and then save as a materials preset.
    Post edited by vwrangler on
    inquire said:
    I checked with RawArt, and learned that this one has only circumcised. Any product that would modify it to make it uncircumsiced?
    Thanks, SpottedKitty, for trying to help.
    What about this prodiuct (just found it on another site): Foreskin-and-Piercings-for-Genesis-3-Male-Genital Note: Mature images. Not dirty, in my opinion, but shows genitalia. Don't click on the link if you don't want to see that.
    Does anyone know if the above product will work on a circumcised gen? It seems to. Or, does it need an uncircumcised one to begin with? Note: Mature images. Not dirty, in my opinion, but shows genitalia. Don't click on the link if you don't want to see that.
    Yes, that product works on a circumcised genital; the foreskin morphs are expressly designed for that.
  • inquireinquire Posts: 2,436
    RawArt said:
    Definitely picking up the prince! Is there a brow less option?
    Yes...I was convinced to make a browless version for these characters :)
    What is the advantage of a browless version? I'm not criticizing; I'm just asking.
    CZ said:
    I bought the male version. His morphs, face and body, are absolutely awesome! And thank you so much for the 'no brows' option. That is really usefull to me. :)
    Is it that you will paint your own brows on? I'm just trying to understand why some wanted the no brows option.
    vwrangler wrote: Yes, that product works on a circumcised genital; the foreskin morphs are expressly designed for that.
    Thank you for answering that for me.
    edited July 2016
    I attached the gens, selected his main body, and used the Albane 02 Mat 1, Iray. The materials were applied to the figure. Nothing happened to the gens. I'm on a Macintosh, using OS X 10.11.5, if that makes a difference.
    I tried this once, starting  with a new scene, and double clicking on the Albane 02 CHR IRay. Then I applied the gens to that. I also tried this by double clicking on the Genesis 3 Male. Then I applied the gens. Then I selected the figure and double clicked the Albane 02 CHR IRay. Same result: Nothing happend to the gens. How am I supposed to get the materials on the gens?
    OK, after multiple trys, I got it done. I had to go the Genesis 3 Male route first. After applying the gens, and attaching it to the figure's hip, I had to make sure everything was selected and highlighted in the Scene Tab, and then apply the Albane 02 Mat 1.
    Post edited by inquire on
  • TSasha SmithTSasha Smith Posts: 27,327
    I guess the browless option is for ones who want to use modeled brows verses painted on brows?  Or if they wanted to change the color of the character's hair?
  • RawArtRawArt Posts: 6,085
    kyoto kid said:
    ...curious, it mentions in the product description that the skin textures for Princess Ali uses the G3Male UV, not Female UV.  Is that correct?
    If that is what it says, then it must be a typo....she obviously uses G3F mapping
    edited July 2016
    I really like a certain type of straight across eyebrows. Many gen 3 men have pluced thin arched brows so I prefer to change that. I also am into the new oh my brows product from rendo. It is easy to replace brows if there are none there to beginning with. Also brow less skins make nice aliens
  • FusionLAFusionLA Posts: 249
    edited July 2016
    @RawArt
    You did it again!
    I was able to give Prince Albane a rest once you relased Igigi.
    Now Prince Albane is back from the retriement home all rested and ready to go:)
    Suprised there was no bundle for Albane and Ali.
    Hope to see a Genesis 3 version DokkAlfar.
    Thank you for continued great work.
    Post edited by FusionLA on
    FusionLA said:
    @RawArt
    You did it again!
    Thank you for contiuned great work.
    I want to see a Genesis 3 version of DokkAlfar too
    edited July 2016
    FusionLA said:
    @RawArt
    You did it again!
    Turns out DAZ did not think think the albino look would sell well, so they did not want to commit to a bundle set. But I am pleased to say Albane is doing well.....Ali is only doing half as well as Albane, but I never do too well with my female sales.
     I think I still have to learn how to make "Pretty women" promos...I am good with monsters and heros, but "pretty" is tough for me. (even though I know the character is great...I just have a tough time showing how great ;)  )
    As for Dokkalfar.......I do have some interesting ideas for them. Something different than what was done before. But they may still be a while off.
    Rawn
    Post edited by RawArt on
  • nemesis10nemesis10 Posts: 3,831
    edited July 2016
    Albane is a lot of fun to render with.
    1619 x 1209 - 373K
    Post edited by nemesis10 on
  • nonesuch00nonesuch00 Posts: 18,773
    That render by nemesis10 is excellent. You can't tell the started with a DAZ character.
    There has been 'Look at my Hair' update, a Singular Inversion FaceGen Pro update, and now this Albane & Ali II new product. It is getting easier and easier to create an original base character in DAZ Studio this month.
    I guess I will buy these too. Thanks to RawArt.
  • KeryaKerya Posts: 10,943
    Because some people want to add fibermesh eyebrows instead of painted on eyebrows ...
    I'm glad you were able to find a way to get it to work. I don't know why that happened to you; it worked for me the way I mentioned. (That said, I also saved off a separate material file for the gens, just to have it.)
    Albane's textures on a toon face, looks great to me!
    2000 x 2600 - 7M
  • kyoto kidkyoto kid Posts: 41,984
    edited July 2016
    ...thanks.
    Just for the record:
    978 x 358 - 183K
    Post edited by kyoto kid on
  • CZCZ Posts: 160
    I have some eyebrows that work as usual hair, which I like to use. In other cases I insert some different colour brows with image editing software. To me it looks really strange, if the eyebrows don't match the hair color. And with given brows there are not much hair color options left to use. Especially for blonde male characters you often get the look of dyed hair as most of the characters have dark brows. Usually I try to eliminate the brows befor rendering in the textures, but that often looks weird too and is a lot of additional work. So I'm really happy about the very few characters which have the no brows option.
