I need to convert G3M clothes into G2M clothes
faisanfaisan Posts: 600
I got to transfer G3M Morphs in the G2M figures thanks to GenX Addons in order to export them in Poser, but I have problems with the clothes. I can't export G3M clothes into Poser, I mean I can, but I can't conform them like I show in the picture.
I used this method:
But how can you see in the picture, the cloth can't be conformed. I tried using this method too:
But it didn't work either. I tried to save it as a wearable present, as a character present, as a shaping present, but that didn't work either, also I loaded the G3M cloth into the G2M figure and it could be conformed in Daz thanks to Autofit function, but I couldn't export it to Poser either. I don't have problems exporting G1 and 2M cloths in Poser using the second method, but with G3M clothes, it doesn't work. So, what I need to do, is converting the G3M clothes into G2M clothes in Daz and that way, I can export them to Poser without problems, the trouble is how?
Do you know any method to convert G3M clothes into G1 or 2M clothes in Daz Studio guys? I know Daz Store has a program called Wear them All, but I think it's only for G3F clothes and I need to convert G3M clothes.
So, can you help me guys?
  • Richard HaseltineRichard Haseltine Posts: 109,220
    Use
    http://www.daz3d.com/genesis-3-male-for-genesis-2-male-s
    http://www.daz3d.com/genesis-3-female-for-genesis-2-female-s
    to convert the clothing to the Genessi 2 figure, then File>Save as>Support Assets>Figure prop Asset. Create a PoserCF for the preset saved there and use it to load into Poser.
  • faisanfaisan Posts: 600
    Ok, I'm going to try this and I'll let you know my results. Thank you for the information! :D
    Use
    Ok, it worked!! Thanks!! Well, when I tried to export it to Poser, it didn't work, but I used the second method of the video and I got to export it correctly, because the cloth was converted in a G2M cloth. Thanks a lot! Now a last question, I got to transfer the G3M Morphs to the G2M Figures with the GenX Addon, but I'm having problems with the figure textures. What is the correct method to transfer the G3M figures textures in the G2M figures?
  • FSMCDesignsFSMCDesigns Posts: 12,849
    I don't recall any product that allows for genesis 3 textures to work on genesis 2 figures, the other ways around, yes, but not backwards.
