Did anyone try these in Iray
Hera
Hello!
Just curious as these are two products in 3Dlight which I love - have anyone tried them in Iray, and how did it work?
http://www.daz3d.com/wonderous-wares
http://www.daz3d.com/metalized-glass-shaders-for-daz-studio
Post edited by Hera on
The meshes from Wonderous wares will work in Iray using Iray shaders but none of the shader presets will work as they are specific to 3Delight. Same with the Metalized Glass Shader, its just a shader and is specific to 3Delight and will not work in Iray.
DimensionTheory has lots of simular iray prests that could easily be used to recreate the metalized glass quickly and easily - http://www.daz3d.com/dimensiontheory
I don't have Wonderous wares.
The Metalized Glass shaders were designed for 3DL, and will take more fiddling than just slapping it with the Iray uber shader to convert.
Both images were rendered with just a single distant light. The darker one is 3DL (and I forgot to turn on the shadow) and the lighter one is Iray. I changed the shader that I used on the plane the sphere is sitting on, but nothing else (besides the render engine)
There some excellent Iray glass and metallized glass shaders available.
Thanks! Now I know, I should stick to 3Dlight if I wish to use these things.
I have a few of the Iray ones of course, but I'm especially found of these two mentioned
