Female jackets
Oso3D
I want to autofit the jacket from Alternate Identity ( https://www.daz3d.com/alternate-identity-for-genesis-2-male-s ) to G2F.
What I want is for a jacket that fits reasonably and, well, hangs off the breasts. Like loose jackets do.
I HAVE Fit Control, Ultra Bodysuit, Genesis supersuit. I know about hidden morphs. I have GenX2 so I can make a G2M look like G2F.
I keep running into the problem that while I can smooth over the transition between breasts and torso, it still pretty obviously follows the outline (and has an annoying kink under the breast that plays havoc with the zipper).
I could convert to dynamic, but then the zipper goes kablooie.
If I dial down the 'female'ness, I end up skewing the arms out of alignment. I've mostly managed to dial away the breasts for the jacket, but then it's submerged in her body and I have no easy way to smoothly 'scale forward' the torso.
Halp?
Normally, there is an "Expand All" morph in the clothing for this sort of thing, at least in my experience.
I know this is probably not very helpful because not everyone can afford it, but this is one of the reasons I bit the bullet and got ZBrush. I can fix just about anything with GoZ...
How about a quick trip into Carrara (which you already have) using the displacement/smoothing brush to create a morph?
- Greg
Any tutorial around on how to do that? Me am having 0 clueness.
