Shanda Hair for G2F - file missing
TaozTaoz Posts: 10,288
edited July 2016 in The Commons
Is anyone else getting this error when trying to load one of the iRay textures?
I've tried uninstall/reinstall, doesn't help.
Post edited by Taoz on
  • Richard HaseltineRichard Haseltine Posts: 109,054
    Does it not work? I suspect there's an error in the path, but unless the hair comes with multiple UV sets it probably won't hurt in use - though you should report it as a possible bug.
  • TaozTaoz Posts: 10,288
    It seems to work anyway if I just click OK, I just don't know if it works as it's supposed to.
    The hair comes in both a G2 and a G3 version, I only have the G2 version but for some reason it installs materials under both G2 and G3. I get the same error whichever material set I choose. I imagine it may have something to do with some reference mix up between the 2 versions, since the error refers to the G3 version.
    Anyway, I'll report this and see what happens.
    Thanks!
    Ah, yes - it's clearly looking for the G3 version's UV mapping, but I would expect they are the same so just clicking through the error will use the default UVs and the textures will fit.
    edited July 2016
    Looks like you're right. There are however also problems with the G2M version, which is included - the hair loads as a black box and I get a similar error. In this case the file is there though, but I've noticed a double slash before the file name. Windows usually handles double slashes in paths without problems in most cases, but it looks like DS doesn't.
    444 x 291 - 38K
    You could edit the file for now, as I think you are right - I had some items broken by double-slashes in the path a week or two back - but again please report this (or add a note to your existing report).
    Well there's no hurry on my part, was just checking. Both errors are reported now so I guess an update will show up in DIM soon. Thanks.
