MIMIC PRO
TWO Questions does mimic pro work in DAZ Studio 4.9 64bit
and does it support importing of prerecorded audio
finking of purchasing as lipsync crashes daz 3d
Mimic Pro was a stand-alone application, although I am not sure how well it could hve been amde to work with Genesis 3 as it requires a cr2 for the figure; however the only version in the store, as far as I can see, is a plug-in for Carrara.
Thanks for your responce Ihave found another method in this forum lipsync in 32 bit save then render in 64 bit workd great thans
Its to bad that mimic 3 pro standalone is no longer available
We recently discovered that it works quite well with the genesis 2 model at least .
Simply do a one time export to poser CR2 and load that into the mimic pro session manager
Here is a recent test we did wth genesis 2 female
thats quiet good will stick with lipsync
LipSync is definitely usable.
A few things that could be done to help tuning imported lipsync in DS:
Tweak Mimic Live! slightly so it could import prerecorded audio files (so users don't have to have 2 DS opened simultaneously when animating actors)
Aniblocks display wave form: AniMate2 does import audio files. But without wave form showing on audio aniblocks, animators are left in the dark.
And poor Genesis1/2/3, all the visemes and wasted facial animation potential.
DS has so much animation potential beyond dead-eye girl gyrates from point A to point B with unnatural pout....
+1
+1
Hate to resurrect such an old thread, but I'm trying to get Mimic Pro to work with Genesis 2. I created a cr2 file for G2, and am using the dmc file from Daz, but when I use these in Mimic Pro, it's like the character won't open their jaw, so there are lip momements, but the mouth doesn't open. Any suggestions?
I this mac compatible?
