New old content will not install
cherpenbeck
in The Commons
There are three new items from runtime: Link Gear Dynamic Cape V4/M4, The Dragon Braid Bundle. The Owls Bundle, which will not install by DIM. I get them downloaded, but the it says: Install Failed.
Yes, I know that they contains items which are Poser only, but does that mean I have to install them by hand to get the things which do work in DAZ?
There are several items moved over from runtime that initially fail installs, you can manually install them to use in the meantime but they do eventually get updated to work with DIM install (some items quicker than others I guess it depends how many log tickets to highlight it!)
I have had trouble with these as well. So I opened tickets.
Dragonkeeper was just updated today, so check back with Install Manager. Open tickes for anything else that doesn't work.
There's hundreds of items for them to convert, so some bumps in the road is expected.
Yeah, I ran into the same problem and submitted tickets as well.
I have the same problem with the Owls bundle, but I haven't tried to manually install yet.
FACADE: Lucrezia installed, but it doesn't seem to have all the files. I did try manually installing this one, but most of the needed files don't seem to be in there. It seems to install but when I apply a shader I get a Missing Files error message. I can't find the needed files when I search either download (the DIM or the manually downloaded).
The DragonCorona did download and install correctly for me, so its not everthing in this group. This item is a huge bargain, btw. It looks wonderful.
I've had updates show up the last few days. Looks like it is being worked on. Tickets do let them know which need to be looked at. :)
