Shoe Stretching
HolyEterniaHolyEternia Posts: 14
I am currently workin on several products and I have a technical question. I have an object completely rigged and setup in Daz Studio but I am getting a stretching problem. Whenver I bend the heel or toes the shoe starts to stretch. I have a screenshot to shoe what is happening.
First image the shoe is normal. Second image the shoe stretches when the toes are bent and the heel stretches when the foot is bent. Does anyone know how to fix this? I am guessing either the shoe would need to be reskinned with weight painting or some type of JCM would be needed. If anyone has any info on the subject it would be appreciated.
Post edited by HolyEternia on
  • Richard HaseltineRichard Haseltine Posts: 109,284
    If you are still using the automatic weighting then yes, you will need to edit it - for a shoe like that you probably don't want the toes to bend at all (the sole would usually be solid) and the heel should have a uniform weight across all its vertices.
