Kiki Hair, anyone tried?
HorusRaHorusRa Posts: 1,665
Anyone one know if http://www.daz3d.com/kiki-hair-pack-1  works well in Studio (IRay or 3Delight), or any of the other hairs for that matter?
​She comes with one hair and it does not seem to want to play well with Studio (or at least for me) no matter what, IRay, 3Delight, Uht hair shaders, nothing seemed to work.
​Help greatly appreciated as always.
  • Digital Lite DesignDigital Lite Design Posts: 728
    edited July 2016
    Hair in image top to bottom:
    1. Load hair and render and you get transparent.
    2. Load and Remove the Trans map from the Opasity channel and it should look normal.
    3. Load and apply UDT shader then remove Trans map from Cutout channel.  Again, will look like it is supposed to. :)
    For some reason all the LLF toon hairs want to throw that map in there.  :)  Take it out and you should be fine.
    (Unless you are having a different isue?)
    500 x 650 - 94K
    Post edited by Digital Lite Design on
  • HorusRaHorusRa Posts: 1,665
    Hey thanks =) and yes that was the problem, it was so transparent you could barely see the hair. Awesome, thanks.
  • Anytime.  Glad to help.  :)
