virtual penny 4 yor carrara thoughts ?
1679111259
  • wgdjohnwgdjohn Posts: 2,634
    edited June 2016
    Gee... I didn't know that it mattered which way the target help was faceing... I've always thought of it a single point and only used it to point the a Camera at. When would you want to rotate it?
    Post edited by wgdjohn on
  • de3ande3an Posts: 915
    If you use it with the Track modifier you can make other objects track the target's rotation.
    Now it makes sense.
    the hot point of camera doesnt seem to point forward from the lens?  sending it to irigin, the lens is on the batting cage floor.
    lightbulb hotpoint is facing out the bottom?
    thinkin to group target helper, camera, and sunlight, so that camera is always seeing the sun (or moon) wherever it is in the sky.,
    or point at sun/moon
    edited June 2016
    For an image showing where it loads and how I think it should load w/settings see http://www.daz3d.com/forums/discussion/comment/1308431/#Comment_1308431. My post before that is similar but sitting on a plane after making additional changes.
    If the sun/moon you mention are actual 3d models then you can simply use point at in your camera Modifiers. Both Camera/modifiers Point at and Track point at and track the sun/moon light themselves from what I have been able to do. Using Track Position put the camera into an upside down position, sky at bottom/land at top of screne, and I've not been able to correct it. :(
    Help... Misty lead me down into the dark forsest then ran off... now let's see what direction did we come from.
    edited June 2016
    i'm using the sunlight/moonlight from the light types.  testing moving the hotpoint on the light >.<
    epically wanting to render like in rara. but with floating fortresses instead of sea ships
    this too, yearns
    more cores!!!!!!!
    Post edited by Mistara on
    Kewl Idea.
    can only see the sun squiggle when light is selected ... well, if cant bring the camera to sun squiggle, bring the squiggle to the camera?
    edited July 2016
    tee hee heeeee
    dust in the wind
    cant find the physics demo i was remembering, it showed a ball rolling around like a roller coaster
    so this is what puppeteer is
    rofl
    ahaa
    start at :51
    dreamin  Vray plugin for carrara
    https://www.vray.com/newsletter/learn_vray/
  • FifthElementFifthElement Posts: 569
    One of my very old Carrara videos have that wink
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,003
    I even did a silly try
    heartheart luvvv the roller coaster physics!!!!
    was just thinkin, fun idea, like make the track part invisible?
    would like to do render some arch vis stuff like in rara.
    zen of lighting and shadows smiley
    https://www.amazon.com/DOSCH-3D-Building-Interiors-Cinema4D/dp/B0030WOGG4
    tee hee - translate klingon
  • PhilWPhilW Posts: 5,160
    MistyMist - I would venture to say that you can achieve renders like this in Carrara already, and there are a number of ways to achieve it.  My "Realism in Carrara" videos go into detail about how to use Carrara's native render engine to produce very realistic results, including interiors.  Your other choices include Luxrender and Octane, both of which will produce extremely realsitic results (and Octane very fast as well, albeit at a higher cost).
    the lighting in bottom image looks soft
  • DUDUDUDU Posts: 1,945
    Hi Misty !
    Thanks for let me know the video about UV mapping, I made some tests and I can use this very interesting feature now.
    ... and thank you for referencing my video! smiley
    DUDU said:
    Hi Misty !
    which one is it?  smiley
    guessing utoob name is different?
    Crash !!!
    DUDU said:
    Crash !!!
    Thanks for posting Crash.  collision distance!
    edited July 2016
    admiring your water work!
    i know i'se doing it wrong.  i enable the light through transparency in both checkboxes, then have to walk away from my render rig for a week.
    i'se a fool for the pumped up settings.  and it's prolly unnecessary on so many levels.
    need more cores!!
    oh my gooooodness
    4,500greenbacks for a 12core / 24thread
    W7370-387
    Case
    CoolerMaster HAF X Full Tower Chassis
    • IO Panel:
      • USB 3.0 x 2
      • USB 2.0 x 2
      • Audio x 1
      • Mic x 1
      • e-SATA x 1
      • 1394a x 1
    • Dimensions: (W x D x H): 230 x 550 x 590 mm / 9.1 x 21.7 x 23.2 inch
    • Bays: 6 5.25", 5 3.5" (hidden)
    • Fans:
      • Front: 230 x 30 mm red LED on/off
      • Top: 200 x 30 mm fan x 2
      • Side: 200 x 30 mm fan x 1
      • Rear: 140 x 25 mm fan x 1
    Power Supply
    EVGA SuperNOVA NEX650G
    • 650 Watt ATX PS2
    • Rails:
      • 3.3V: 25A
      • 5V: 25A
      • 12V: Split 53A/53A
      • 5Vsb: 3A
      • -12V: .8A
    • Dimensions: 85mm x 150mm x 180mm
    • Efficiency: 90%
    • Warranty: 10 Year, requires EVGA Registration
    Motherboard
    SuperMicro X10DAI Workstation Motherboard
    • Form Factor: EATX (12" x 13")
    • Processors: Dual Intel® Xeon™ model E5 26xx v3 (2011-3)
    • Chipset: Intel® C612
    • Slots:
      • 3 PCI-E 3.0 x16
      • 2 PCI-E 3.0 x8
      • 1 PCI-E 2.0 x4 (in x8)
    • Memory: Up to 512GB ECC (16x 288-pin DDR4 DIMM sockets)
    • SATA: 10x on-board SATA 3.0 (6 Gbps) ports
    • Network: Dual i210 Gigabit Ethernet
    • Audio: HD Audio (Realtek ALC888 with s/PDIF header, Optical S/PDIF)
    • USB 3.0: (6: 4 rear + 2 via header)
    • USB 2.0 (5: 1 2 rear, 2 via header + 1 Type A)
    • Other: TPM 1.2 20-pin header, 2x COM Ports (1 rear, 1 header)
    CPU
    (2) Intel® Xeon™ E5-2650 v4
    • 12-Core
    • 24-thread
    • 2.20 GHz Processor - Socket R3 (LGA2011-3)
    • 30MB Cache
    • 105W
    CPU Cooling Solution
    (2) Gelid Socket 2011 Cooling Solution
    Memory
    32GB DDR4-2133
    • Crucial or Kingston RDIMMs
    • DDR4-2133
    • 8 Modules 4GB
    • ECC Registered Low Voltage (1.2v)
    Video Card (Or Select 'Video-Onboard' to use onboard video)
    EVGA GT730 (01G-P3-2731-KR)b>
    • Specs & Pictures
    • Superclocked
    • Memory: 1024MB, DDR5 64bit
    • GPU Clock Speed: 902MHz
    • Processing Cores: 384
    • Memory Clock Speed: 5000Mhz
    • Memory Bandwidth: 40GB/sec
    • Bus: PCI-E 2.0
    • Interface: DVI-D, HDMI, VGA
    • Concurrent Display: 3 Monitors
    • Resolution Max
      • Digital: 4096x2160
      • Analog: 2048x1536
    • Slots: 2
    • Supports: DirectX 11, Blu-ray 3D
    • Choose Minimum 300 Watt Power Supply
    PCIe SSD
    Item Not Selected
    SSD 1 - 2.5"
    Item Not Selected
    SSD 2 - 2.5"
    Item Not Selected
    Hard Drive 1
    Western Digital Model WD2003FZEX
    • Caviar™ Black Edition
    • 2 Tb SATA 600, 64mb Cache
    • 7200RPM
    Hard Drive 2
    Not Selected
    Professional Video Cards (AutoCad, Solidworks, etc)
    No Professional Video Card Selected
    Primary Optical Drive
    LG Blu-ray Rewriter
    • Max CD Read Speed: 16x
    • Max CD Write Speed: 48x
    • Max CD Rewrite Speed: 24x
    • Max BD Read Speed: 12x
    • Max BD Write Speed: 16x
    • Max BD Rewrite Speed: 12x
    • Max DVD Read Speed: 16x
    • Max DVD Write Speed: 16x
    • Max DVD Rewrite Speed: 8x
    • Optical Media Supported: BD-R/RE
    • Media Layer Supported: Double-layer
    Productivity Software
    Not Selected
    Operating System
    Microsoft Windows 7 Professional 64-bit
    • OEM System Builder Packaging
    • Includes DVD & Key
    LCD Monitor
    No Monitor Selected
    Keyboards
    No Keyboard Selected
    Network Cable, Category 6
    No Network Cable Cable Selected
    1099 x 636 - 122K
  • TangoAlphaTangoAlpha Posts: 4,586
    Bung a pair of water cooled Titan-Xs in it (while you can still get them) and it'll render Iray too . . . wink
    i need the cores to render 60fps.  vrooooom vroom
    I felt a disturbance in the force... oh yeah... prolly just MistyMist with all dem cores.
    Let the spice flow - pumpkin spice
    So beautiful http://www.daz3d.com/wildenlander-watch-hd-for-genesis-3-male-s
    so incompatible with Carrara crying
    I just cry
    I shall buy it
    I shall fight to fit it on G2M and render it in my one true software loves I shall not be defeated
    maybe even rig a polygonal obj exported HD version using the Transfer Utility in DS on the converted original though it ahall grind Carrara to its knees.
    (or at least try running it through Xnormal if it helps)
    Gianni 6 shall wear it Misty and He shall look AWESOME!!!!!!!!!!
    edited July 2016
    OK need bit of work still may need to use the sheaf as a prop, hid it for  now but SickleYields merge heirachies suggestion in Transfer Utility after converting to triax worked well, cape even has all the g3m facial bones!!!
    1920 x 1080 - 1M
    click to play
    looks good.
    merge heirarkies, interresting
    ise working on this between challenge projects
    want color animate go-for-launch sequence.   sky hammer launcher needs special effects
    trying to remember what millenium falcon animated for launch.
    cold beer helps think  lol
