Shaders don't work
allyxp000allyxp000 Posts: 23
edited July 2016 in New Users
Hi! I don't understend why the files don't exist in my pc ... What can I do?
Post edited by allyxp000 on
  • evilded777evilded777 Posts: 2,485
    I suggest you uninstall and reinstall the Default Resources for Studio 4.9 through whatever method you installed them
  • allyxp000allyxp000 Posts: 23
    I reinstall it from the menager ... but it's the same ... :(
    Then there is most likely a problem somewhere in how your directorys are set up.
    :/ mmmm... Does this product work in your Program?
  • Richard HaseltineRichard Haseltine Posts: 108,594
    edited July 2016
    That shader is working for me. The files it needs are being placed in the application folder, not in the content directories, so are you getting a UAC prompt to allow DIM to make changes on your system while isntalling, and are you allowing it to do so?
    I searched in the zip of the product the files that the program can't find for make the shader work, but in the zip there aren't the png that I need ... :(
    You are right, they are not in the Default Resources package they are in the main Daz Studio Package.
    edited July 2016
    I searched the missing files in the programs folder of the pc, but they don't exist ...
    Maybe I can download them online from somebody ... ?
    Um... NO.
    Seems from what Richard said, that maybe you need to uninstall and reinstall Studio.  Why don't you try that instead?
    WHAT!? If I'll do it I'll have to reinstall al the products? OMG, I'm afraid ...
    No, uninstalling DS should not affect anything other than the application files - content and settings should be untouched.
    Okay, I try to reinstall Daz Studio!!
    Reinstalled! But ... all is the same ... Same problems
    Which version of DS is this?
    4.9 (32-bit)
    edited July 2016
    Iray is 64 bit only, so you will not get the Iray sahder files with the 32 bit version. You get the shader files as the Default resources package is for both versions of DS (on both OSes) but you can't use them.
    Ah, okay ... so the default resources that I search don't exist for 32 bit ...
    Thank you for the help ;)
