Selection in Surface Pane using script
I know how to select node by label (findNodeByLabel( "..." )).
But how to make this in Surface Pane - to example choose "Opacity" or other item here? Thanks wink
  • EdpaEdpa Posts: 46
    edited July 2016
    I tried next, but it isn't working :(
    parameters are not changed
    var oPaneMgr = MainWindow.getPaneMgr();var oPane = oPaneMgr.findPane( "DzSurfacesPane" );var item = oPane.findPropertyByLabel( "Glossiness" );if ( item) { item.setValue( 50 );}
    Post edited by Edpa on
  • Richard HaseltineRichard Haseltine Posts: 109,360
    You would do better to go to the item directly rather than through the pane. This script sample shows how to get a material from an object and access its properties http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/properties/material_properties/start
    edited July 2016
    Ok! It's working correctly.  Changes a little and OK. Thank you very much.
    Modified place from this script :)
    // Iterate over the materials
    for( var i = 0; i < aMaterials.length; i += 1 ){
    // Get the "current" material
    oMaterial = aMaterials[ i ];
    //printMaterialPropertiesInfo( oMaterial );
    // Find a specific property by name
    oProperty = findElementProperty( oMaterial, "Horizontal Tiles", false );
    // If we found a property
    if( oProperty ){
    // Provide feedback
    oProperty.setValue(2 );
    // Finalize the function and invoke
