surface selection by value of ... instant crash.
alan bard newcomeralan bard newcomer Posts: 2,378
edited July 2016 in Daz Studio Discussion
yes, I filed a bug report... or it's trying too submit one as I type this...( five minutes to say a blank order number must be filled with N/A (hint put a note in the HTML?*
--_
so is this a known bug or my computer just being special
used the "surface selection tool"
sub... select all surfaces with the value of....
clicked to accept dialog...
crash ... instantaneous to the desktop... no "oh my god, I've had an issue message" ... just gone...
not even a fatal error here's my crash report...
repeated to attempt to recreate the issue... was successful...
* well glad I copied the bug report data here... see attached picture...  so the bug report system has a bug...
one minute later... I back paged from the page below to the bug report form and hit submit and it went through... good grief...
Post edited by alan bard newcomer on
  • Richard HaseltineRichard Haseltine Posts: 109,310
    What property did you pick to select by? What figure, does it make a difference if you use a different figure (or use 3Delight instead of Iray/Iray instead of 3Delight materials if there's a choice)?
