mcjManchon - Fence-net prop with many morphs - Ready !!
Post edited by mCasual on
Wow very cool. Thanks for sharing.
workin on it
adding a bit more morphs
well contrary to what i was saying the prop's tubes will be 1 morphing object
but i'll also supply single tubes clockwaise and counterclockwise so you'll be able to build fences and things
IT's READY !!
https://sites.google.com/site/mcasualsdazscripts7/mcjmanchon
so you have 2 manchon props and a torus with 2 morphs, one to change the minor radius, one to change the major radius
i though the i could morph between manchonA and manchonB, but it doesnt give the effect i wanted
so i made 2 props and gave them the same 10 morphs
Read the instructions they're short but give you an important info
is it possible wrapping around an object ?
the big picture cannot be seen
i reposted the big image it shows the 10 included morphs
there's not enough morphs to adapt it to random shapes
but someday i'll probably post the script i used to built this fence-mesh
that script with the help of mcjCollider plugin can build the mesh around a leg or a body with perfect precision
nice to see you've got it to work
nice thank you for this great prop!!!
