Problems with Autofit on custom figure
Daz v4.8 / 3Delight
So I made a really nice custom G2F figure using morphs from an existing figure but now I seem to be having an issue where clothes don't fit right around the waist (see attached).  Since most 'pants' that I've tried don't seem to have a morph to make the waist smaller, and Fit Control doesn't seem to have anything for this, I'm wondering what my next step would be to get clothes to fit right in this area?
  • Richard HaseltineRichard Haseltine Posts: 108,687
    Is that all trousers/skirts/belts or only one set? In general if the clothing item doesn't support all of the morphs used DS will generate new ones, but some items have overly extensive Rigidity groups applied which can put the kibosh on all morph matching that isn't covered by built-in morphs.
  • Stryder87Stryder87 Posts: 899
    So far I've experienced it on a few different sets.  This is one (http://www.daz3d.com/gallery/#images/157776) although I was able to hide it pretty good adjusting the scale of the object.  The item in the screenshot I posted was http://www.daz3d.com/get-funky-josie. ; Sometimes I can change the scale of the object to hide the issue, or shift on an axis, but that isn't always available (don't know why).
    It's not a rigidity group on that set, which doesn't seem to have any at all on the shorts..
  • BejaymacBejaymac Posts: 1,957
    Are any auto generated morphs getting added to the clothing, if not then odds are the "Default" setting is the same as the "Value" setting in the morph's parameters, when it's like that DS doesn't realize that anything has been changed so doesn't create the auto generated morphs.
     After re-reading your comment about 8 times because, at first, I didn't have a clue what you said (hahaha... sooo tired.....), I think I get what you're asking/saying.  The main morphs I did was adjust the torso/breasts larger than the default figure I used as my template, widened the waist, thinned the hips and thighs.  I haven't seen any issues with the chest/breasts, but since there are so many morph packs available, plus morphs that come with custom figures, I'm guessing the basic rigging of that area makes it pretty reliable that that area will auto generate a proper fit.
    However, the area I'm seeing the most issue with is the waist/hips.  I'm not sure what you mean about the Default setting (would this be what the default figure had before I adjusted it?) and the Value setting (would this be what the final morphed figure is?).  How do I make sure DS is seeing the morphs settings?  Where would I check this?  With all the customization abilities, I'm actually surprised this would even be an issue.
