Two character morphs with the same name - this why the morphs disappear when I close & re-open?
GatorGator Posts: 1,320
I tried creating a new character from P3Design named Tara.  Body & head morphs load up, customize her, then save.  Upon re-opening later (merging into a scene) the morphs don't appear on the mesh - they say they are there, but don't seem to be applied.  Move the morph dials, or use the remove & add morph DUFs nothing.  Opened just the character file, same thing.  Thinking something went wonky, started over from scratch again with the same results.
Could it be that I also have a character named Tara (from Kayless) with identical morph names?  How can I fix it to use these characters?
http://www.daz3d.com/tara-sachra-hd-for-victoria-7
  • Richard HaseltineRichard Haseltine Posts: 109,366
    If it was duplicate labels there would be a (2) on the parameter slider so I don't think that is the issue. However, I don't know what might be the issue - you are not alone in seeing something like this though, so I would suggest opening a support ticket and attaching the saved file with a note of the content used.
  • GatorGator Posts: 1,320
    OK thanks, I submitted a support ticket.
