PC+ monthly discount codes
rampart_1576840087
I tried to apply the discount code several times on various content items of Daz Originals, even tried new items.
The code does not activate. Does this mean the code discount cuts off on the last day of the month or something?
Here is code I entered. It is still June 30 where I am.
06-16PlatClub
Post edited by rampart_1576840087 on
Which items did you try? It says that it's not valid on PC items.
Daz Original items...
http://www.daz3d.com/daz-originals
http://www.daz3d.com/heavy-motorcycle-wasteland-addon
They include PC items.. so make sure you don't have any of those in your cart.. failing that, try splitting order up if it has a lot in there just to heln narrow it down.
Yes, I realize the Daz Originals are lumped in with the PC+ items.
The cart had one item in it and would not apply.
Could it be when accessing the Daz originals via the PC+ block something is different.
Yet, I went over to the sale block for tutorials special and found 3 items that were daz originals.
The discount applied to those items- $6.99 items - 6.00 = $.99 cents.
Also, I don't like to apply less than $5.00 on my credit card.
I didn't want those items... I was testing only.
I think Daz3d could avoid alot of confusion if they had specific search/sort on Daz originals (less PC+items)
I can search/sort on PC+ items, why not Daz originals since there are constant sales targeting daz orginals.
Try this link:
http://www.daz3d.com/daz-originals#&filter_platClub=0&filtered=1
I tested it and it seems to be working.
- Edit, I used the July code so ...
