Help advice. It's just one minute please!
Super cheese sandwich
Which pack is the best for fast rendering?
PACK 1
-Motherboard Asus x99 deluxe with 5 pci slots
-Processor Intel i7 5930k
-1x 980 ti
-1x 970
PACK 2
-Motherboard Msi Z87 Xpower
-Processor Intel i7 4790
-3x 980 ti
-1x 970
Thanks for comment
Post edited by Super cheese sandwich on
It will help if you are able to give specific details on the harware. Generalization is harder to answer because your idea of high end may be different. The best option is an X99 motherboard and a CPU that handles 40 pcie lanes or more. Then spend the rest on a couple 980 Ti then add whatever else you want after.
Sorry kat. I edited it
I notice you have a much better Z87 motherboard in PACK2 compared to the previous post.
You could probably do without the 1 x 970 if it's just for monitors. Just use the on-board graphics for the monitors and you'll have room for a fourth 980ti.
If this is just for Iray then PACK 2 and 3 x 980ti is easily the better option.
PACK 1 has better 3Delight performance, is a bit more future proof, more expandable, but obviously more expensive.
Can you wait till August? We should know more about the nvidia 1080 and Iray by then.
Imagine that both PACKS have the same number of graphic cards. There will be a huge difference in rendering performance?
Graphics cards are essentially self contained and will run the same on any system. (Unless you have a really poor power supply, the wrong motherboard, bad case cooling)
You're right, if you already have the graphics cards, then PACK 1 makes more sense.
