anatomical elements don't fit anymore
The genitals don't fit anymore.
There seems to be a gap between the body and the genitals bodypart.
It occurs with genesis 2 and 3 male and female.
Are you using them on the matching base figure? Are they fitted to the figure?
Yes.
Matching same base figure and fitted to the figure.
But there seems to be a gap on both genesis 2 male and female and genesis 3 male and female.
Seems that the element isn't connected anymore.
Is it fitted to the figure - check the Fit to button in Parameters.
yes it is fitted to the figure
Is the geometry editor selected by chance?
Out of curiosity, are you viewing the scene (Go to Tool Settings) in any other mode than "Universal"? Because I sent a rather embarrassing Zendesk request along the same lines, until I realized that I was viewing in Geometry Selection mode.
Was just about to say the same think about the geometry editor. I was so confused when that happened with Cayman's Legacy UV geografts
Thanks a lot guys. That was the problem. When I switched over to universal the problem was fixed.
