anatomical elements don't fit anymore
Babs 33b1905Babs 33b1905 Posts: 23
edited June 2016 in Daz Studio Discussion
The genitals don't fit anymore.
There seems to be a gap between the body and the genitals bodypart.
It occurs with genesis 2 and 3 male and female.
  • Richard HaseltineRichard Haseltine Posts: 109,184
    Are you using them on the matching base figure? Are they fitted to the figure?
  • Babs 33b1905Babs 33b1905 Posts: 23
    edited June 2016
    Yes.
    Matching same base figure and fitted to the figure.
    But there seems to be a gap on both genesis 2 male and female and genesis 3 male and female.
    Seems that the element isn't connected anymore.
    Post edited by Babs 33b1905 on
    Is it fitted to the figure - check the Fit to button in Parameters.
  • yes it is fitted to the figure
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,496
    Is the geometry editor selected by chance?
  • SkirikiSkiriki Posts: 4,976
    Out of curiosity, are you viewing the scene (Go to Tool Settings) in any other mode than "Universal"? Because I sent a rather embarrassing Zendesk request along the same lines, until I realized that I was viewing in Geometry Selection mode.
  • RedzRedz Posts: 1,459
    Was just about to say the same think about the geometry editor. I was so confused when that happened with Cayman's Legacy UV geografts
  • Thanks a lot guys. That was the problem. When I switched over to universal the problem was fixed.
