Problems with posing
CZCZ Posts: 160
I tried to pose Joy as I did several times before, but now I have problems with that. I only tried to bend the shoulder to get the arm down, but it come out very bad as you can see in the attachment. For comparison I did the same with Rune and it worked perfectly. Is somebody else facing this problem? And what can I doo, to get it fixed?
Thanks a lot!
Post edited by CZ on
  • CZCZ Posts: 160
    edited June 2016
    Another try: Shoulder bend at 80/-80 for all characters, Joy, Rune and Alice. I'm sure I haven't had this problem some days ago. Don't know what happend there.
    1467 x 1204 - 134K
  • CZCZ Posts: 160
    edited June 2016
    I closed Daz and started it again with a new scene. No changes. It is getting worse if I use one pose preset. I tried several poses for G3F, but basically they all look weird like this one. Poor Alice.
    1058 x 1317 - 66K
  • Cris PalominoCris Palomino Posts: 12,678
    Select Joy and then look at what is listed under currently used in the Shaping Tab.  What's listed?  Do you have the morph packs that were required?
  • CZCZ Posts: 160
    Wow! That's crazy. I just closed and opened Daz again, as I did several times before. I reopened the same scene from above and now everything is fine. I haven't changed anything. I really don't know what happend here. Also the pose preset works now.
    1315 x 1185 - 111K
  • Richard HaseltineRichard Haseltine Posts: 109,282
    Something had broken the link between the morph and the joint centres, which need to be moved when a shape changes the size or position of the mesh belonging to a bone - in this case making it smaller, so without the adjustments the centres of rotation were further out than the shape needed. If it happens again please open your log file (Help>Troubleshooting>View Log) and work up from the bottom to see if there are any errors relating to loading the figure or adding the character.
  • CZCZ Posts: 160
    Thanks a lot! I will keep that in mind. But hopefully this will not happen again. For now everything works fine again.
  • CZCZ Posts: 160
    Since than I had to face this problem several times again. But usually it worked if I closed and opened Daz two or three times. But now it is not that easy. Currently I have a scene with Izabella 7 and some custom morphs, where the posing gets weird. I lokked at the log file and the only thing, I can see, which semms to be related to the morph are these warnings:
    2016-07-08 08:07:38.387 *** Scene Cleared ***
    2016-07-08 08:07:41.001 WARNING: fileinput\dzassetdaz.cpp(5503): Could not find output property for formula: Genesis3Female:/data/DAZ%203D/Genesis%203/Female/Morphs/DAZ%203D/Karen%207/FHMKaren7.dsf#FHMKaren7?value in file : /data/DAZ%203D/Genesis%203/Female/Morphs/DeviousDolls/Vanda/CTRLVanda.dsf
    2016-07-08 08:07:41.001 WARNING: fileinput\dzassetdaz.cpp(5503): Could not find output property for formula: Genesis3Female:/data/DAZ%203D/Genesis%203/Female/Morphs/DAZ%203D/Karen%207/FBMKaren7.dsf#FBMKaren7WholeBody4?value in file : /data/DAZ%203D/Genesis%203/Female/Morphs/DeviousDolls/Vanda/CTRLVanda.dsf
    2016-07-08 08:07:41.269 WARNING: fileinput\dzassetdaz.cpp(5503): Could not find output property for formula: Genesis3Female:/data/DAZ%203D/Genesis%203/Female/Morphs/DAZ%203D/Measure%20Metrics/PBMWaistCircumference.dsf#PBMWaistCircumference?value in file : /data/DAZ%203D/Genesis%203/Female/Morphs/Chevybabe25/Vincenzina/Vincenzina%20Body.dsf
    2016-07-08 08:07:41.269 WARNING: fileinput\dzassetdaz.cpp(5503): Could not find output property for formula: Genesis3Female:/data/DAZ%203D/Genesis%203/Female/Morphs/DAZ%203D/Measure%20Metrics/PBMLowHipCircumference.dsf#PBMLowHipCircumference?value in file : /data/DAZ%203D/Genesis%203/Female/Morphs/Chevybabe25/Vincenzina/Vincenzina%20Body.dsf
    2016-07-08 08:07:41.987 File loaded in 0 min 3.6 sec.
    2016-07-08 08:07:41.987 Loaded file: 001.duf
    But I don't know how to fix this problem. So I would love to get some hints what to do now. Thanks in advance. :)
