Gray Renders
AnuszczykAnuszczyk Posts: 62
Hi All,
This is my first post. So, please excuse me if I do something incorrectly.
Some of the items in the store include renders of the product without any shader/textures. They're just plain gray. Is there a setting in DAZ to do this or do I need to manually remove the shaders from every object in the scene?
Thank you very much for your assistance.
Jim
  • Richard HaseltineRichard Haseltine Posts: 109,129
    Not the shaders, but you would need to remove the Diffuse colour maps and set the colour to white or light grey (remember that it will be dimmed somewhat by the lighting. Open the Surfaces pane, select all of the surfaces on the item (quickest way is to click its name in the list to the left of the pane), click the little square next to the Diffuse colour bar and pick None from the menu, click the colour bar to pick a new colour. That should do the job, though you may want to adjust other properties too.
  • AnuszczykAnuszczyk Posts: 62
    Thank you very much for the quick response. I appreciate the help.
    Jim
