White spots on G2F Carissa
Hi all, I'm wondering if anyone else is having the same problem with Carissa that I am. In the preview pane, her skin appears fine. However, after rendering her skin has these white spots in various areas. I have used the default Carissa, as well as used other G2F figures with Carissa's skin. They all get the white spots. For example picture I used the default Iray settings with Photoreal selected. Anyone know how to fix this?
  • jcbunnjcbunn Posts: 271
    looks alot like reflection from the light source.
    is it set to sun, sky
    or are you adding your own lights
    Specular is set too glossy.
  • TymefyreTymefyre Posts: 16
    Thanks for the help.Problem solved (I hope)
    @ jcbunn: I was using the default light when no lights are put into the scene, no background, no sky dome, etc. I usually do that to get an idea of what the figure looks like.
    @jestmart: I had to reduce the Specular glossy setting from teh default to almost 0% before getting rid of the white spots.
