Where would you get makeup options for V7?
whitefirewhitefire Posts: 0
edited June 2016 in New Users
Where would you get makeup options for V7? Like in the title. I want more options but preferably not as strong as the ones from the Vicky 7 bundle. I was thinking about something like this http://www.daz3d.com/l-i-e-make-up-set-2-for-genesis-3-female-s or things from here: http://www.daz3d.com/growing-up-skin-merchant-resource-bundle-for-genesis-3 .Would it even work on Victoria 7? Or maybe there are other options? Where do you get your makeups? (well, not YOUR...)
Edited to add question to body of post.
  • IceDragonArtIceDragonArt Posts: 12,966
    The growing up skin is not really a make up option.  But the LIE makeup sets are cool and pretty easy to use.  There is this one, the vendor has several different sets as well.  http://www.daz3d.com/artistic-make-up-concepts-2
    I am eagerly anticipating a script to put your own make up together like they have for Gen2F.
  • FerretmaniaFerretmania Posts: 883
    Forbiddenwhispers has some make-up sets too :  http://www.daz3d.com/forbiddenwhispers
  • jcbunnjcbunn Posts: 271
    edited June 2016
    Now for lip color (lipstick) you can change that at any time in the Surfaces pane.
    up top, click windows then mouse over panes (tabs) then go down to Surfaces and click on Surfaces.
    then check out this image ( I clicked on the White bar in Diffuse Color and changed its color to what ever I want )
    this works on any charactor
    1249 x 759 - 119K
    Post edited by jcbunn on
  • Richard HaseltineRichard Haseltine Posts: 109,527
    Note that the Genesis 3 figures have a Lip surface that extends beyond the limit of the lips - to allow blending with the skin more smoothly, but it does mean that titning the surface will have undesirable results.
    thanks for the info Richard
    edited June 2016
    Just changing the color will give a very hard edge, a bit beyond the actual lip...like this
    512 x 640 - 640K
    Post edited by mjc1016 on
