apply a shader on eyes and hair
Hi,
I got a problem...
With my shaders packs i want to create a cartoon like (or a draw like) but when i select all my items i have a problem on eyes, and same for my hairs (see the screenshot, please), are you an idea ?
Another question, can you advise me for create a good line art ? Like cel shading. Because i bought pw toon and manga style shader but it's not cool at all (no abds, and muscles...).
Thanks
Post edited by Chohole on
I'm assuming you are using 3Delight for rendering, because both shader packs you mentioned are 3Delight only.
The first problem I see, is lack of transparency maps...for 3Delight, this would be image maps (black and white...black = transparent; white = opaque) plugged into the Opacity channel, in the Surfaces tab. With the default settings, the should be there...
If you hold down Ctrl when applying the shader a box will pop up under Map Settings choose ignore and the trans maps should remain in place.
There are different sliders in the surfaces tabwhich change the look of PWToon and the manga style shaders I'm more familiar with the PWToon than the manga but you get back details by altereing them usually the Diffuse upper and Lower Bound helps with shadows on muscles etc. Also your lighting will make a difference as will the original maps.
Thanks for the precious advises, i'll take a look about that tommorow !
nice, it works !
Thanks again :)
