Warrior Make-up for Genesis 3 Female question re UV's...
jakibluejakiblue Posts: 7,281
http://www.daz3d.com/warrior-make-up-for-genesis-3-female-s
Description states: This L.I.E. Set was created using the Genesis 3 Base Female UV Set but can be easily adjusted as needed to work with any of the Genesis 3 Female UV Sets.
I'm trying to figure out - can these makeups be used on a character that is wearing say, the Olympia 7 uv? Can they ONLY be used when using a skin texture that is G3F base UV? What is the "easily adjusted" if you are using the Olympia 7 skin?
  • Jan19Jan19 Posts: 1,109
    Good question.  I put Arabella's normal maps on a G3 character and everything went haywire once.  I wonder if normal maps work on the same principle as that makeup set you're referencing.
  • I responded to Jaki earlier on FB and saw she had opened this thread as well so I figured I would just show my findings here too.  The work very well for most of the "core 7" characters with the exception of Julie, Girl (waaayyy off lol) and Mei Lin.  Here are a couple quickie renders I made for that FB thread.  The one on the left (if it shows up like it does for me while typing this) is straight up Olympia with the paint applied.  The one on the right is on Olympia but I changed only the uv for the face to base female.  A slight difference but if they weren't side by side like this you wouldn't even know.  I also tested the body paint and those seemed to work pretty well also.  Of course I can't show those though lol.
    1320 x 1560 - 1M
    1320 x 1560 - 2M
