Skinbuilder Pro UV not lining up - G2F
From the product page: "Please note Victoria 5 is only required if the product is intended to be used on Genesis. Genesis 2 Female(s) comes with V5 UV's standard, therefore Victoria 5 is not required to use this product on Genesis 2 Female(s)."  Really?  Than why is this happening with G2F?  Obviously if I use a different UV, the Bree materials will not line up.
  • krickerdkrickerd Posts: 222
    Okay, wait.  You HAVE to load SkinBase first, (the one that has a "DO NOT CLICK" and strikeout icon on it?  Not very intuitive.
  • Richard HaseltineRichard Haseltine Posts: 108,161
    Victoria 5 is required for Genesis to have the right UV set - that doesn't mean that textures using a different UV set will work, just that if you don't have the V5 UVs nothing will work.
