Looking to export Genisis as a Character into DAZ Studio 3
sjjesso_78ca0e6d0csjjesso_78ca0e6d0c Posts: 79
Why am I looking to do this? I used Face gen to create face morphs for Genisis and I wanted the character created to be it's own Character rather than being another Genisis Figure and 2) Because I primarily still use Studio 3. I'm not a fan of studio 4/4.5's layout and prefer the older program. Set in my ways I guess. Well I try to export as a Poser file but when I import it into DAZ 3 the figure becomes distorted (long limbs, out of wack rigging). I'm guessing it's because DAZ 3 automaticly begins to load The Genisis OBJ rather than the OBJ I exported. I know it can be done for Poser, but I don't know what's going on here.
  • fixmypcmikefixmypcmike Posts: 19,700
    DS3 doesn't support PP2012 weight-mapping -- you would need to rig the figure using Poser legacy rigging.
  • dyretdyret Posts: 188
    You could get Bryce and use the bridge to export Genesis from Studio 4 to Bryce, then use the brige to export the result to Studio 3. LOL
  • sjjesso_78ca0e6d0csjjesso_78ca0e6d0c Posts: 79
    edited October 2012
    Well that sucks. Guess I'm going to have to use DAZ 4 whether I like it or not, and I don't. While we're on the subject can anyone explain why the hands and feet get distorted every time I use a pose that's not for Genesis? None of the Previous models like Michael 4 did that. I know there's a script to correct the problem but I have to run the script each time I pose Genesis which slows things down.
    I don't understand the Humor in this.
    Post edited by sjjesso_78ca0e6d0c on
    None of the Previous models like Michael 4 did that. I know there’s a script to correct the problem but I have to run the script each time I pose Genesis which slows things down.
    The point is that Genesis is a completely different model to any that went before. It is a brand new figure, it has different rigging, and it is a single skinned figue too. Clothes for Genesis will generally fit any morphs of Genesis (within reason). I think if you try it in DS4 you will be amazed at what it can do.
  • MattymanxMattymanx Posts: 6,997
    Though that was an issue in the past, I do not see the hands and feet weirding out at all on Genesis in DS45 no matter what gne4 pose I apply to it
    Did you try Rage Pose for Freak 4 (as shown in this pic)? This is the #1 issue I have with this model and the #1 reason why I don't like to use it very often.
    640 x 480 - 53K
    M4 and V4 have translations on the hands and feet locked. Genesis did not in DS4.0, but the DS4.5 version does, so it doesn't have this problem any more.
    *Scratches head* But I am useing DAZ Studio 4.5. I uninstalled Studio 4 and installed studio 4.5.
    It wasn't meant as humor as such. It's just a bit long and winding. Sorry if I offended you, but my solution is actually doable.
    No offence taken, I just though you made a funny and it went over my head.
  • PuntomausPuntomaus Posts: 450
    I've tried all of the DAZ poses for Freak 4 and even the Freak 3 on Genesis and the feet are ok. But none of the poses I've tried looked like yours, though.
  • Knight22179Knight22179 Posts: 1,195
    I don't usually get this problem either but when I do, I just use the Node Selection tool, click on the offending body part and then go to Edit>Object>Zero and click on Zero Selected Items. :)
    edited October 2012
    Adamr001 has a script to fix hands and feet when the do stuff like that.
    http://forumarchive.daz3d.com/viewtopic.php?t=170864
    Post edited by mjc1016 on
    If M4 and V4 have hands and feet locked why didn't they do the same with Genesis? Was it a ploy to get people to buy Genesis poses or just something they didn't consider?
    Oh and a quick update. For whatever strange reason the feet of the Genesis model have stopped screwing up even when I used poses that screwed it up before. I don't know why but I'm not complaining.
