M5 Skin Overlay Box
hello,
Does anyone have trouble with the dialogue box for the M5/V5 skin overlay script? It's too big. accept or ok at the bottom is below the task bar. I changed screen resolution and it still is hidden. also tried to resize and it jumps. thanks
You need a vertical resolution over 768 pixels to see the full dialogue - unfortunately with the move to 16:9 aspect ratio displays 768 pixel displays are suddenly common again. One workaround is to use the Tab key - click on the last visible control, click again to put it in the state you want it in, then press tab until the highlight disappears off the bottom of the screen and either then or after another tab hit the spacebar to perss the Accept button.
