Genesis 3 Female Head Morphs
Hi guys,
I just bought Genesis 3 Female Head Morphs and I dont know how to use it/cannot find it within the layout the same way I am used to using everything else that I normally purchase through Daz. Any hints or tips most welcome! Thank you kindly!
  • Richard HaseltineRichard Haseltine Posts: 109,000
    The morphs appear under \Actor\Head in the parameters pane when you have Genesis 3 Female selected, allowing you to set their values as desired. They are also accessible through the Shaping pane, using the Region Navigator tool to target the area you want to change.
  • The morphs appear under \Actor\Head in the parameters pane when you have Genesis 3 Female selected, allowing you to set their values as desired. They are also accessible through the Shaping pane, using the Region Navigator tool to target the area you want to change.
    Thank you very much yessmiley
