mcjDespeckle - PCWin app Remove fireflies in iRay - New! Daz Studio Frontend
mCasualmCasual Posts: 4,607
edited June 2016 in Freebies
also fine for Cycles/Lux/Octane renders
The "fireflies" observed on path-traced renders are distinct from noise in photos
they are usually 1 pixel-wide and quite bright compared to surrounding pixels
my filter takes advantage of this and detects them quite well
HD1080p images are filtered in a fraction of a second ( no real limits on the image size other than your PC's ram )
It's a PC-Win Application, .exe
command-line driven but you can also just drag and drop an image on it and it works
>>> instructions and download
https://sites.google.com/site/mcasualsdazscripts7/mcjdespeckle
note: if writing .bat files is really too complicated for you
in a few minutes, I'll post the .bat files discussed in the "manual" in a zip file
i added (Mac?) in the title because as you see below, i may publish the WebGL version someday, which should run in Mac browsers
Post edited by mCasual on
«1
  • TugpsxTugpsx Posts: 796
    Wow, another great tool from you. Thanks for sharing.
  • Cris PalominoCris Palomino Posts: 12,490
    Casual, I'm unable to see the images.  Did you remove the thumbnails?
  • RuphussRuphuss Posts: 2,631
    msvcp140.dll is missing
  • mCasualmCasual Posts: 4,607
    thanks i thought my app would only need DLLs present on any windows, but apparently ... not
    i will recompile it in a way  that the dll in question is in the belly of my .exe
    (instead of sending people to .dll sites that can be dangerous )
    if you mean the images in my Daz3D forum post, they show up for me
    but if you dont see them here you'll see them all on my google sites page, because that's where they reside
    new version, is bigger 126K instead of 21K - and if i did it correctly, it wont need the services of those DLLs
    so it wont run on Vic-20s but may run on Commodore 64's with the extra ram cartridges :)
    edited June 2016
    UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE
    The new version should annoy you about missing DLLs because the functionalities from those DLLs are now in the app itself
    also, i added a pack of 5 batch files which are easy to figure and edit
    800 x 1035 - 1M
    thank you mcasual
    v2 works nicely
    first post pics cannot be seen
    edited June 2016
    Ruphuss said:
    thank you mcasual
    v2 works nicely
    thanks for your testing efforts !
    i replaced the linked photos by attached ones in my original post
    800 x 1600 - 2M
    that's my image despeckler, converted into HTML5/WebGL code
    running in a Chrome browser on Windows 7
    it takes a fraction of a second to process the millions of pixels !
    when/if i make this public, it should work on PCs, Macs maybe tablets and phones too
    anything with a browser that supports webgl/HTML5 code
    for now at least i had to run my Chrome browser with a special code that tells it: "it's safe to let the web page load my disk images"
    the annoyances of the internet security state
    i would like to use this for picture series of movie clips
    could these be worked on in one session ?
    edited June 2016
    lets say your images are named
    if you type this in notepad
    then you save this under the name PicoMovipic.bat
    and Run this batch file (double-left-click on it )
    then your 120 pix___.png images will be  filtered and saved as
    ( sometimes i create that type of batch file in excel )
    my store worz video was despeckled that way
    i may eventually make a daz script that does all this for you ... but not today !
    if you can figure what this daz script here does, then feelfree to use it .... in the Daz Scripting Editor panel
    for(i=0;i<120;i++)
    if(i<10) paddedi= "00"+i;
    else if(i<100) paddedi = "0"+i;
    else paddedi = i;
    debug( "mcjDespeckler pic" +paddedi + ".png mypic" + paddedi + ".jpg" )
    or you could download the text file attached to this post
    and do a little search&replace
    then save it as myfilterbatchjob.bat
    txt
    txt
    BatchFile120PNGToJPG.txt
    5K
    thank you mcasual
    i remember you can do that in excel with an increment
    will try
    my jpg go down from 2mb original size to 300kb
    edited June 2016
    the jpg exporter in my app is gdiplus , i didnt consider the jpg quality/compression
    next version will have 100% quality by default and/or a command-line switch to set it how you like
    in the meantime you could specify png as the output format, even if your input file is jpeg it will work
    there's also bmp, gif and .tif you can try
    ex:
    mcjDespeckle myfile.jpg myfile.tif
    incidentally, i despeckled a 24 frames animation today!
    cold you please just for testing render this to a movie file in daz and look at the ram behaviour ?
    i see the ram stay as high as it can and cannot get rid of it even if i declare only few cores for daz
    even if i delete everything in the scene
    you cannot work any further then and i have to restart daz studio
    i opened a ticket for this and need some assistence
    i render to movie just for quick testing animations
    the ram behaviour with image series is not like this
    edited June 2016
    I'll write a Daz Script front-end (maybe someday a blender front end ) for the despeckler
    the first time you run it, you specify the location of mcjDescpeckle on your hard disk
    then you can select 1 image to despeckle
    if the image is part of a series of images, you'll have the option of despeckling the whole series
    you'll also be able to specify the despeckling strength and the output image format, which by default will be the same as the input image format
    800 x 1440 - 2M
    edited June 2016
    I rendered many scenes as movie files
    usually in uncompressed format because i convert them to gif later
    no memory problems so far
    i still use DS4.9.0.63 and have 8G or ram
    my video card has .... 2G
    renderers like iRay and Cycles need to upload all your images to the video card
    so if you use a Genesis figure and her many 4Kx4K pixel images are in the scene, sometimes it doesn't fit in the video card memory
    and can do mean things like crash the renderer and leave it in a non-responsive state
    in the iRay render settings itself there are some settings like "Environment Lighting Resolution" which may influence memory usage ( though maybe in that case it's just the render time that is affected )
    and in the NVidia iRay render settings, in the Advanced tab there's the "Texture Compression" settings panel
    by reducing those settings value i think your big Genesis3 textures get shrunk before being sent to the video card
    also, i often use Windows Task Manager to destroy the zombie-daz-studios that didn't die when i used and closed them
    sometimes there's 2 zombie Daz Studios holding on to memory and who knows, maybe the video card or the iray renderer
    another thing : some Codecs have a tendency to crash when you try to use them to save your avi/movie file
    i had this happen a few times, and i can never remember which ones are safe and which ones are not
    so i save them as uncompressed videos or as series of images
    then i use VirtualDub to create the DivX .avi files
    1193 x 616 - 47K
    thank you  mcasual
    i forgot to say these issues are only with interactive mode
    movie and image series
    photoreal does not behave like that
    but very nice you evolve the despeckle script
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,121
    yes I too would love an easy to use image series option, filters in Hitfilm are OK but your despeckle does an awesome job, I honestly think if you could make it a plugin  filter for Virtualdub or other compositing software you could market on somewhere highend even like CGsociety it as users of other PBR render software could use this too!
    edited June 2016
    * NEW * NEW * NEW * NEW * NEW * NEW *
    Control mcjDespeckler from the comfort of Daz Studio
    Including the 1-Button filtering of image sequences
    this way ---> https://sites.google.com/site/mcasualsdazscripts7/mcjdespecklefrontend
    616 x 501 - 52K
    800 x 300 - 88K
    edited June 2016
    Tip
     it works best if your render is in png or bmp or tif format because the filter counts on the presence sharp bright pixels and jpg format smudges them
    if your image contains just a few dozens or hundred bright pixels then you can reduce the filtering ( by using a factor like 200 )
    this way the despeckler will remove the bright pixels but not burn the object contours too much
    in the image here, if the filter setting is the strongest ( factor=0) then some of the bright reflections on the bike paint would be corroded
    800 x 600 - 847K
    edited June 2016
    oops
  • Sky77Sky77 Posts: 820
    That is fantastic!   Looks very user friendly.   Thank you!
  • Mustakettu85Mustakettu85 Posts: 2,933
    yesThank you so much!!
  • SkelchSkelch Posts: 276
    edited July 2016
    I just tried this on an image I had that needed this badly. Thank you so much in just a drag and drop my image was cleaned up. I am so thankful to you!
    Post edited by Skelch on
    edited June 2016
    Welcome!
    at first i thought i'd just release it stand alone
    but having the Daz Studio interface leads me to use it a lot more myself!
    there's a quirk but i forget what it is, something about .png ... so i'll fix that next time i encounter the issue, maybe it was for animations
    a recent despeckled image
    vs something like this originally
    Skelch said:
    I just tried this on an image I had the needed this badly. Thank you so much in just a drag and drop my image was cleaned up. I am so thankful to you!
    810 x 1080 - 501K
    800 x 1067 - 1M
    hi Mcasual
    you think it is complicated making a script that enhances or decreases a graph of an animation in percentages ?
    and thank you for the despeckle script
    very useful
    edited June 2016
    i made a script named something like "moderate your face" i think it may be usable for other animations, it's for morphs though.
    http://www.daz3d.com/forums/discussion/45233/mcjmoderateyourface-script-to-curb-your-figure-s-enthusiasm-ds-1-5
    For rotation animations, you can  use mcjCycleFilter to change the minimum and maximum values the animation curve is allowed to swing
    https://sites.google.com/site/mcasualsdazscripts/mcjcyclefilter
    plus it's a good way to view curves for short animations - for longer animations there's my mcgSceneGraf plugin
    https://sites.google.com/site/mcasualsdazscripts2/mcjscenegrafds45
    unrelated image
    Ruphuss said:
    hi Mcasual
    very useful
    1280 x 1920 - 227K
  • N-RArtsN-RArts Posts: 1,605
    Now that's impressive! To be honest, the whole "firefly" thing put me off rendering in Iray, but this is brilliant. Thank you for sharing (P.S. I love your avatar).
